Flywheel & FI - Quite possibly the dumbest question I have ever asked
Old Dec 14, 2004 | 10:17 AM
mcduck's Avatar
mcduck
Default Flywheel & FI - Quite possibly the dumbest question I have ever asked
Getting ready to upgrade my clutch and flywheel and I'm going with the light weight JUN flywheel.
Will the quicker revability of the motor affect my Vortech boost tune in any way?
I mean, right now, if I'm in neutral and rev the motor to 5-6K, its going to wind and build boost way faster than I will be able to running the lighter weight flywheel under load, right?
Not saying I won't ever retune, but it would be a pisser if I had to go retune immediately just because of the flywheel change.
Old Dec 14, 2004 | 10:53 AM
jpc350z's Avatar
jpc350z
Interesting question..Logic would indicate that you should build up boost sooner. With a reduction of rotating mass that's been robbing you of available torque the engine load is less allowing quicker boost buildup..Can't imagine a retune would be required or would provide any significant gains. However my logic and reality are not always consistent. Interested in what others believe..
Old Dec 14, 2004 | 10:56 AM
mcduck's Avatar
mcduck
I agree, it would seem logically the boost would come on sooner, but I guess my question is whether it would be moreso than just sitting in neutral and revving the motor... that, IMO, is the quickest you can possibly rev.
I'm asking not because I anticipate tuning for more power, but rather to gauge whether I'm endangering my motor by changing the boost dynamics from making it rev more freely. If I retune, it would be for safety reasons.
Old Dec 14, 2004 | 11:46 AM
jpc350z's Avatar
jpc350z
You will accelerate faster and in time you will match the new quickness with a reduced pedal to the metal to give you the response you now have at higher boost levels except of course if you want to take advantage of the additional torque and go like a bat out of hell. A lower level of boost results in lower rpm. If you want to maintain your present boost levels it seems you will rev at higher rpm's and go faster than your present set up. .. Making any sense?
Old Dec 14, 2004 | 01:17 PM
luanda's Avatar
luanda
Mcduck, I am running a custom Vortech install with a Jun flywheel - only 2-3k so far but no problems.
Old Dec 14, 2004 | 02:17 PM
enthuzd's Avatar
enthuzd
FWIW, with the gutted RT cats, stock flywheel and the stock pulley my max boost was 7.1lbs. With the 3.12 pulley and Nismo flywheel, I now make 9.4lbs. Could the 2.3lbs be all pulley??? Maybe... Has anyone else seen 2lbs or more from just going to the 3.12??? I think the flywheel did increase boost in my situation.
BTW Andy, I really like the ACT street clutch and Nismo flywheel combo. However, I might go with a lighter flywheel if I had it to do it all again. I can tell that the engine revs quicker and more freely, but I'm not sure it is going to be all that much better for the track than the stock combo...
Did you choose a clutch?
Old Dec 14, 2004 | 02:24 PM
350zWarz's Avatar
350zWarz
doesn't the boost depend on the rpm's, if so it would just go through the rpm's quicker i.e. boost comes on quicker but still at the same rpms....all things the same besides the addition of a light weight flywheel... right?
Old Dec 14, 2004 | 02:38 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
You will not have to retune. If you car revs faster, the boost will bulid faster, and you fuel and timing will enrich and retard faster. It is all a linear process....everything will be the same in terms of tune....things will just happen a lot faster.
Old Dec 14, 2004 | 02:51 PM
booger's Avatar
booger
I had gutted RT cats and made 7.lb's boost with stock pulley . Added 3.12 pulley and made 7.6lb's.......added crawford cats....9.5lb's . So yes it seems the flywheel made some boost for you....if you didnt do any thing else , but every car is diff.
Old Dec 14, 2004 | 02:55 PM
enthuzd's Avatar
enthuzd
Hey Bill! How's the progress on your car? What made you decide to go with the Zeitronix?
Old Dec 15, 2004 | 10:20 AM
mcduck's Avatar
mcduck
Thanks, Sharif... Your answer makes the most sense to me (though I appreciate everyone's input!)
luanda... was the JUN already on your car when the SCed? My question was toward adding the lighter flywheel after already being boosted.
enthuzd... I know of at least one other person who saw a similar boost gain out of just upgrading the pulley to the 3.12".... so I think 2-2.5lb gain is status quo for that mod.
enthuzd #2... Decided to go with the CM III clutch. It sounds like it will meet all my needs (handle my power, still mostly streetable, correct price) and I am going to be able to get it quickly because gq_626 has one he has decided not to put on his car because he will be building it even stronger soon!
Old Dec 15, 2004 | 10:22 AM
Sharif@Forged
Forged Performance
Originally posted by mcduck
enthuzd #2... Decided to go with the CM III pulley. It sounds like it will meet all my needs (handle my power, still mostly streetable, correct price) and I am going to be able to get it quickly because gq_626 has one he has decided not to put on his car because he will be building it even stronger soon!
Cool..I think you meant CM III clutch. I didnt know they made pulleys too!
Old Dec 15, 2004 | 10:34 AM
mcduck's Avatar
mcduck
Just had to quote me didn't ya? Now my edit makes me look completely foolish! A feat that is surprisingly simple...
Old Dec 16, 2004 | 10:50 AM
luanda's Avatar
luanda
Yes it was, which is to say my tuning incorporated it. I asked if the lightweight flywheel would make a difference and they said probably not...wouyld just enable engine to spin-up (and spin-down) more quickly.
Old Dec 16, 2004 | 11:09 AM
mcduck's Avatar
mcduck
which I believe is what has been concluded with this thread. Thanks for the input! Entering upgrade mode with no worries now.
Dr.Paulyy
Jul 29, 2019 07:45 AM
bcoffee20
Nov 19, 2015 06:39 PM
Ace2347
Sep 22, 2015 03:12 AM
RyansZ33
Sep 15, 2015 05:54 AM
