Return Fuel System Questions
Old Dec 31, 2004 | 10:17 PM
ReavTek's Avatar
ReavTek
Default Return Fuel System Questions
Hey Guys,
As you know I'm trying to build up my Z to be a reliable twin turbo. After checking out the ********** pages I ran across an article that scared me:
http://www.**************/forums/ind...showtopic=3545
*'s = **********(DOT)com
It shows how the stock fuel system does not evenly distribute fuel to all the cylinders. The solution they offer is a return fuel system. What is a return fuel system? How does it work? I can't really visualize what it is doing.. It is like some other kind of secondary fuel rail? Please go into as much detail as possible as I am very eager to learn.
Thanks
Old Jan 1, 2005 | 10:06 AM
DBZCat's Avatar
DBZCat
there is so much information on this board and my suggestion is to go to the search and put in return fuel system and several threads will come up about it.... you will have ALOT to read and it will probably answer all your questions....
that is how I learned alot of the information I know.
as for the return fuel system, I would go with AAM. so you can do a search on AMM fuel return system as well. It is definitely something you want for TT
Old Jan 1, 2005 | 12:30 PM
dynamic6er's Avatar
dynamic6er
Default Re: Return Fuel System Questions
Originally posted by ReavTek
Hey Guys,
Thanks
The factory setup is returnless. This means the fuel flows out of the pump and up to the front of the car where the rails are. The fuel then goes into one side of the rails (ie left bank of the motor) then through a short tube and into the other side. There is no return to the fuel tank.
Take a looks at this thread for more infor and pictures on our system.
https://my350z.com/forum/showthread....hreadid=104405
issyz
Jul 2, 2017 03:04 PM
pslamp32
Feb 8, 2017 09:07 AM
Justin100
Nov 29, 2015 03:58 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
SpartanZ32
Oct 22, 2015 09:36 AM
