SSR/SFR 350Z Twin Turbo Kit *Completion Pics*
Old Jan 20, 2005 | 06:10 PM
  #61
SSR Engineering's Avatar
SSR Engineering
Originally posted by nis350ztt
Bump for answers about the installing, and another question, could you use any tuning module for this kit?
Yes you can use any tuning module for this kit.
Old Jan 21, 2005 | 02:22 AM
  #62
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Thanks for confirming. Now, what about the install, do you have any information about time right now or would it all be speculation. Another question, where could we get this kit?
Old Jan 21, 2005 | 09:02 AM
  #63
SSR Engineering
We deal directly with the public so you could get the kit directly from us. Depending on level of mechanicl skill installation time hovers around 30 hours.
Old Jan 21, 2005 | 06:36 PM
  #64
Brandon@Forged
Thanks for the info.
Old Jan 24, 2005 | 08:26 AM
  #65
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
Jet hot coatings will provide little benefit since we use 321 SS and it has all the heat retention properties as say a cast manifold with a ceramic coating.
Also the manifolds are supported, and even if they do crack we will replace it for free under our life-time warranty.
To add to Alberts statement........Actually the 321SS is a better material then cast iron by every means.It can tolerate temperature upto 2250F.It retains heat like no other metal except for inconel and it is the choice material to use when building turbo exhaust manifolds.The headers are also equal length which means it prevents the exhaust pulses from colliding inside the runners and causing reversion which could lead to preigniton and higher EGTs.
Old Jan 24, 2005 | 08:37 AM
  #66
TurboTim's Avatar
TurboTim
Originally posted by APS
Not sure why you believe the wastegate design has any influence over the turbos spool up performance (wastegates are closed during this phase) and external wastegates don't neccessarily produce any higher power potential than an integral wastegate design.
Thanks
Peter
You might not make more power with external wastegates but you will have better boost control since their are two ports that help to regulate boost instead of one port on internal wastegates.On high horsepower applications, the external wastegates will allow increased flow where internal wastegates would be overwhelmed and cause overboosting,surging,etc.....
Old Jan 24, 2005 | 08:58 AM
  #67
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Do you have a link to support this statement? Even if true, heat rention would depend on the thickness of the walls, not just the material used. How thick are the walls of this manifold? How thick are the flanges?
In regards to cracking, even if replaced under warranty, the labor and hassle to remove them is HUGE. On a Honda, its a 1 hour job. On a 350Z, it is a 10 hour job....at least for your average mechanic.
Old Jan 24, 2005 | 09:55 AM
  #68
Inertia350z's Avatar
Inertia350z
http://burnsstainless.com/TechArticl...s_article.html
Here is a link about 321SS, 304SS and other materials that are used in building headers.Our headers are made out of a 16 gauge 321SS tube.The flanges are 304SS and are 1/2" thick.All of our welding is back purged and we use the appropriate filler rod.
Old Jan 24, 2005 | 10:10 AM
  #69
TurboTim's Avatar
TurboTim
[In short no. Water cooling the turbos bearing housing is the Ultimate solution for all high performance Gasoline turbochargers (this is the exact reason why all Garrett GT series turbos utilise water cooled bearing housings) this eliminates the need to idle down the turbochargers as the engine coolant continues to thermo syphon via the turbochargers after engine shut down, it's all good.
Thanks
Peter [/B][/QUOTE]
I would have to disagree with you.Watercooled turbos will not prevent the bearing sections from coking if the car is shutdown abruptly.I have plenty of watercooeld turbos sitting here with bearing housings that are "coked" up with oil.The watercooling didnt save them:^( A turbo timer will help becasue it allows the oil temoperatures to cool down significantly to prevent coking from occuring altogether.Dont get me wrong I am a big fan of watercooled turbos but it is not a solution for the problem that you were referring too.
Old Jan 24, 2005 | 10:27 AM
  #70
G3po's Avatar
G3po
Thanks
Peter
I would have to disagree with you.Watercooled turbos will not prevent the bearing sections from coking if the car is shutdown abruptly.I have plenty of watercooeld turbos sitting here with bearing housings that are "coked" up with oil.The watercooling didnt save them:^( A turbo timer will help becasue it allows the oil temoperatures to cool down significantly to prevent coking from occuring altogether.Dont get me wrong I am a big fan of watercooled turbos but it is not a solution for the problem that you were referring too. [/B][/QUOTE]
Were these turbos fed Dino or a good synth motor oil?
Water cooling plus a good Sythetic such as Amsoil, Redline, RP etc
should virtually eliminate the coking hazard.
Old Jan 25, 2005 | 02:42 PM
  #71
Sharif@Forged
Forged Performance
with modern ball bearing tubos, regardless of cool down techniques..chances of ruining a turbo due to coking is minimal...especially if running synethetic. Hell, even the primitive T3/T4 or Mits turbos in the Greddy kit should be good for 100K miles...if decent precautions are maintained.
Thanks for the link, but it didnt mention the heat-retention capabilities of cast iron in comparison to 321 SS. I have no doubt that 321SS is the best application when choosing a tubular steel manifold, but I am not convinced it is better than cast iron in terms of heat retention, or strength.
To me...the biggest risk with tubular steel is the risk of cracking. PE manifolds were cracking left and right, and those things were a work of art. not certain what material they used though.
Old Jan 25, 2005 | 03:51 PM
  #72
TurboTim's Avatar
TurboTim
I will see if I can find another link for you.I seriuosly doubt that PE was using anything other then 304SS.Most companies do not want to incur the higher price of using 321SS.
Old Jan 25, 2005 | 03:57 PM
  #73
SSR Engineering
http://www.intensepower.com/comsoonpowen.html
You're right, the PE kit is constructed with 304SS not 321SS.
Old Jan 25, 2005 | 04:13 PM
  #74
aalzuhair's Avatar
aalzuhair
Cracked Greddy Manifold
Old Jan 26, 2005 | 12:00 AM
  #75
Silo's Avatar
Silo
I guess supporting the turbo is the key...
Old Feb 10, 2005 | 01:39 AM
  #76
kamal34's Avatar
kamal34
Default the SPEED FORCE RACING tt kit
hey Guys, I have their TT setup on my 5AT G35. Its running great and im getting great numbers. I have had it for almost a year now and I have NOT blown. I am very impressed with the response, especially on a heavy car and with it being a 5AT. The APS tt is great too but honestly I dont know much about it. If you do have any questions, call TIM at SPEED FORCE RACING. Hes the actual engineer of the kit and builds all the parts from scratch. They have a great facility and theyve built many cars which have made it into a lotta magazines. Their actually in this months issue of Turbo Magazine towards the end, they got a big article of a black Supra they did. Anyway, I am very happy with the kit and if I had to do it all over again, I would. I am at 410.8 RWHP right now on stock internals. We def could have gotten bigger numbers but that wouldnt be good and safe for the engine and its life span. email me at Kamal34@yahoo.com if you got any questions about how the kits running but the mechanics, email or call TIM at speed force cause no one will know the kit better than him. He makes em.... If your in the LA area, hit me up and I will be more than happy to show you the car and even give you a ride.
Old Feb 10, 2005 | 01:49 AM
  #77
kamal34's Avatar
kamal34
boost we're running on my car right now is 7 psi. Not bad hitting 410.8 at only 7.2 PSI huh..? Sorry the dyno is in Adobe format. How the hell do I change it into a Jpeg or a Jif or watever? I can email it to whoever wants to see. Email me and Ill send it to you right away. If not that then someone PLEEEEZ tell me how to convert it into a diff format!
Old Feb 10, 2005 | 09:12 AM
  #78
G3po's Avatar
G3po
Default WG plumbing
On your arrangement are you
a) running catless?
b) atmospheric waste gate venting (aka. WG not plumbed back into the exhaust)?
Thanx
Old Feb 10, 2005 | 03:05 PM
  #79
kamal34's Avatar
kamal34
The answer to your questions are yes and yes for both. I am catless and have atmospheric waste gate venting...
Old Feb 10, 2005 | 07:21 PM
  #80
thrifiddytt's Avatar
thrifiddytt
Whats SSRs website? Does this kit come with a reflash, piggyback, or standalone? Lifetime warranty is great!! But what is the price and dealers in the SoCal area? Thanks for the answers.
