Greddy TT install - Too early???
Old Jan 14, 2005 | 08:00 PM
accordfreak's Avatar
accordfreak
imo i would wait until a real plug and play standalone is available to tune
Old Jan 15, 2005 | 07:27 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally posted by gq_626
Pauter Forged Rods
Arias Forged pistons 9.0:1 .020 overbore
ARP head and main studs
Basic port matching and valve job
AAM return fuel system upgrade with FPR
RC 550 injectors
ATS twin disc carbon Clutch and flywheel
Upgraded rear wheels and tires.
eManage tuned by CJ-Motorsports (pressure based to 20psi)
goal....20 psi and 600whp.
sharif:
could u elaborate on the e-manage tuning?
so i see your goal of 550rwhp has gone up a bit!?
also, will you have the larger injectors and fuel return put in at the same time as the forged internals and whatnot? what will the tune consist of for the break in period? just a rich street tune for the first couple hundred- thousand miles, then retune on a dyno???
please let me know what you plan to do, this is the part i'm unsure of at this point!!
THanks
what size tires/wheels are you going with???
our setups are almost identical (mostly because i'm copying everything you are doing!)
i was thinking of hitting 450 actual rwhp, wait a month or so, see if any other updates come yup with the Z (seems like something new pops up here weekly ex: crank sensor wire)...then retubne the motor to 550rwhp (actual)- so it'll dyno up here at like 670rwhp on the dyno-sae corrected factors
sales@czp
Sep 23, 2019 03:30 PM
