engine build: new hoses and belts necessary
Old Jan 18, 2005 | 06:20 PM
xsmallpaulx's Avatar
xsmallpaulx
Default engine build: new hoses and belts necessary
if im in the process of doing a engine build is it necessary to get new hoses and new belts. also is it necessary to get them upgraded to stronger ones if my goal is around 550whp or will the stock hoses and belts be strong enough. thanks
Old Jan 18, 2005 | 06:37 PM
g356gear's Avatar
g356gear
Default Re: engine build: new hoses and belts necessary
Stock hoses should be fine..... but like the belts their replacement is mileage dependent. I would do the belts with the re-build just because they are relativelt cheap. For the hoses you could probably go with some new Samco's for a little flash and better quality if you wanted.
Old Jan 18, 2005 | 06:41 PM
xsmallpaulx
i really dont care for the flash of the samco hoses but i was wondering if the stock hoses and belts can handle 550-600 whp?
Old Jan 18, 2005 | 07:00 PM
g356gear's Avatar
g356gear
I think you can get them in black The stockers should be fine because you're not changing the coolant pressure or temp....really. If the temp is getting too high then a better rad might be in order.
Old Jan 18, 2005 | 08:08 PM
bullseye's Avatar
bullseye
Buy new hoses for the silicone base material... upgrading to handle more heat than stock rubber hoses. Buy new belts just because... Good luck with your rebuild, and keep us posted.
Old Jan 19, 2005 | 10:09 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
^^Agree^^ change them while the engine is pulled. My car is 17500miles on it, and I am swapping all of my hoses and belts. Belts will be stock items, hoses will be samco Blue.
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
