Little Show Off My Car (Sorry 56K Guys)
Old Jan 27, 2005 | 01:45 PM
nitrous350's Avatar
nitrous350
I think in this forum has some master tunners
Dear Master What do you think ???? about this Idea
Old Jan 27, 2005 | 09:32 PM
JeffesonM's Avatar
JeffesonM
I probably wouldn't go with two piggybacks... seems like it might not be a good idea. I think you should be able to tune it with the eManage and a wideband 02 sensor. Maybe you could find someone else with similar mods and get a copy of their eManage maps... that would at least give you a good starting point. It will probably take some time without access to a dyno.
Old Jan 28, 2005 | 11:46 AM
BlackTuner's Avatar
BlackTuner
If you are using the Greddy Sensor to gauge your afr you should probably be very careful. I have seen many of our customers cars come in with those gauges and I have yet to see an accurate one.
Old Jan 28, 2005 | 12:28 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Stick with the unichip. The Unichip software is availble from directly from Unichip. I bet a tuning shop in your area could order it and tune it for you. No need for an APS dealer.
Old Jan 28, 2005 | 06:31 PM
basam350z's Avatar
basam350z
You could get by without a dyno if you get a datalogging wideband O2 sensor installed.
Old Feb 2, 2005 | 10:21 PM
nitrous350's Avatar
nitrous350
OOOO Ya
Cause I get Innovate LM-1
Old Feb 3, 2005 | 12:15 AM
Zcool's Avatar
Zcool
Maybe you can get a group of car enthusiasts together to buy the first dyno for your island? It sure would be cheaper than sending cars to Cal or blowing engines.
Old Feb 3, 2005 | 12:42 AM
phunk's Avatar
phunk
CJ Motorsports
yea really... that sounds like a good idea... you can get the new Dynojet 224xlc... 2WD, 1000HP max, and that also has LOAD BEARING for great assist in tuning... Its about $35,000 if believe.... when you think about it, if you had the only dyno on the island you could charge quite a premium and possibly make your money back in a year or two.
BTW I like the car!
Old Feb 7, 2005 | 01:32 PM
nitrous350's Avatar
nitrous350
This is List of what I get in my Car
My Turtle
1> Nismo Cam
2> Racing Edge Converter
3> B&B Exhaust for 03 - On Nissan 350Z w/ 4" Elliptical tips
4> kinetixracing In-Line Resonator Cat Delete pipes
5> NOS Nitrous Wet System
6> Stillen Valve Body Upgrade
7> UR Pulley kit
8> 9.5:1 CP Forged Piston (Custom Ordered)
9> Pauter Billet Rods (E4340 vacuum melt chrome moly forging)
10> Sard 255 Fuel Pump
11> Technosquare ECU reflash = " L " Spect
12> APS TT Kit 8 ~ 13 psi Boost so far now
13> ADR M Sport 18” ( fornt = 245 Kumho Rear = 275 BF Goodrich Drag ..) at Guam Track 26x10.5x15 MT Slick
14> Nismo Wing
15> Apexi Fuel , Oil , EGT , Boost , Trans. Oil Tem Gauges
16> Greddy Wide band A/F Gauge
17> Nissan 6MT 3.58 F/D Gearing Conversion
18> HKS EVC II (Boost Controller)
19> DVD player
20> HKS The Twin Power ignition amplifier
21> SGP Racing SST Brake Line Kit 03 - On Nissan 350Z
22> Progressive Nitrous Control System
23> JDM 350Z Clear Side Markers with Custom Home made LED light
24> Willwood 14" Front Break kit
25> Innovate LM-1 + LMA2
26> Trans. Oil Cooler
27> Pioneer's DEH-P8450 CD/MP3/WMA receiver with CD changer controls
28> Rockford Fosgate Power series amps
29> Infinity's Reference component speaker systems
30> Infinity Kappa Perfect 10" subwoofer
31> Nismo Gas Filler Cover
32> HKS Ground Wires
33> NISMO - Body Graphic Kit 350Z
34> Custom Paint , Battery Cover , Brake Fluid Cover , Engine Cover
35> Custom home made LED dom Light
36> Custom home made radiator Cooling Panel
37> GReddy Racing Iridium Long Reach Spark Plug
38> Samco Sport Coolant Hose Kit
39> LED Parking , Brake , Sginal light bulb Replace
40> 8500K HID Bulb
Old Feb 7, 2005 | 01:58 PM
Sharif@Forged
Forged Performance
That is a sic-assss list, Kim. Very nice work!
Old Feb 7, 2005 | 05:28 PM
nitrous350's Avatar
nitrous350
Talking
Thank QQQQQQ
Old Feb 7, 2005 | 05:43 PM
nitrous350's Avatar
nitrous350
Sorry .....
Old Feb 7, 2005 | 05:47 PM
nitrous350's Avatar
nitrous350
How About this Product
They say we can bored out 100mm
I remember our stock Piston is 95mm If we go to 100mm bored
What is the size of our Engine (4,300 cc) ???????
Darton Mid Sleeve Kit: Nissan VQ35DE
Darton Sleeves, Carlsbad, California -Darton announces the availability of its new Modular Integrated Deck (M.I.D) sleeve kit Nissan's VQ35DE blocks. This block adds to the already impressive line-up of kits like LS-1, Honda, Ford and Ecotec. This kit will allow you to go from a standard bore of 95mm to a max bore of 100mm handling high boost and high compression. The kit is perfect for all applications whether it be full race, turbo, N/A or for those weekend warriors with street/strip cars. This kits shares all the same patent pending designs in the M.I.D. line. George Iannou said it himself " I feel that the VQ35 Nissan engine will be the future of the import drag racing Pro-segment in 2005, its power potential is unmatched." Darton being the leaders in sleeve designs agrees that the VQ35 will play a huge part in racing in the year to come and with this new kit its power potential becomes even better.
StreetStandard
Videos
Feb 4, 2016 09:44 AM
Juztin
Nov 22, 2015 07:03 AM
kyin
Sep 29, 2015 06:57 AM
Bigsyke
Sep 11, 2015 06:19 PM
