What is the weak link above 500 rwhp?
Old Jan 29, 2005 | 04:22 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
So the liners sound more like a brace. If you have a link to someone that sells them for the Z..lemme know. I havent been able to locate them. Since the car you are refering to is a race car...they may be custom fabricated or something?
Old Jan 29, 2005 | 06:15 PM
Enron Exec's Avatar
Enron Exec
Default Re: Re: Re: What is the weak link above 500 rwhp?
Originally posted by Clifton in AZ
I've been doing more searching on transmissions and sleeves. Bluefish has been making alot of power without sleeves. Coming from a cast iron block background I have no idea what the difference between a sleeve and a liner is. Looks like it will be a hit or miss on the gear box. Anyone know if the VG30's have the same bellhousing bolt pattern?
I had something to do with that misconception. bluefish is head of PR for Smithtown Nissan, or Performance Motorsport. Their 13xx rwhp 350Z has custom made sleeves, im guessing closed deck.
Old Jan 29, 2005 | 06:49 PM
Philthy's Avatar
Philthy
Boost Junkie
The motor they're building now will have sleeves and a closed deck... The 1300hp motor just had liners... If the motors are still at the machine shop next week I'll take some pictures to show you the differences.
Old Jan 29, 2005 | 07:33 PM
Sharif@Forged
Forged Performance
get some detail and source out those liners...I might be interested...especially if it doesnt require a modifed or new headgasket.
Old Jan 31, 2005 | 05:42 AM
bruschijr's Avatar
bruschijr
i'd definatley be interested in info on the liners... and how they install. My bottom is already assembled at SGP... do you know if they can still put them in without dissassembling the bottom? I plan to run as close as I can to 600WHP +/- so id definatley be in...
Old Feb 3, 2005 | 01:01 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Bump...
Old Feb 8, 2005 | 11:41 PM
Brandon@Forged
Bump...did you make it to the shop this week?
Old Feb 9, 2005 | 06:35 AM
Philthy's Avatar
Philthy
Boost Junkie
I'm taking a trip down to the machine shop this week and I'll take some pics of the different configurations, AEBS, Darton Liners, and below are some for the Darton MID... I'll also take some pics of the torque plate, and other tools that are used for balancing the motor...
I'll ask Weston to take some step by step pics from start to finish on the work I'm getting done to my block if your want them...
Old Feb 9, 2005 | 07:35 AM
JCat's Avatar
JCat
This is based on my experience with OTHER cars (not the Z).
Once you build the engine, you may have troubles with:
Clutch and pressure plate (they explode)
U-joints and CV joints (they break)
rear differential gears and limited-slip or posi unit (I stripped the ring gear once)
rear axles shafts (they break)
tires and traction problems (burn, bounce, & even broken lugs)
Bottom line: You gotta pay to play.
Old Feb 11, 2005 | 11:34 PM
NissanJunkie's Avatar
NissanJunkie
Has any 400hp++ cars on here have any of these problems so far?
Old Feb 13, 2005 | 09:00 AM
JCat's Avatar
JCat
Yes...here is one of many.
https://my350z.com/forum/showthread....hreadid=109997
You must pay to play.
Old Feb 18, 2005 | 01:55 PM
Brandon@Forged
Bump...
Old Feb 19, 2005 | 09:38 AM
Brandon@Forged
Originally posted by nis350ztt
Bump...
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Tochigi_236
Sep 27, 2015 03:40 PM
