Need Plugs and Injectors for ATI
Old Feb 9, 2005 | 05:55 PM
zcar03's Avatar
zcar03
Default Need Plugs and Injectors for ATI
I have 2 step colder plugs NGK Iridium that I used for my nitrous. Will this work well with the ATI Procharger?
Also I plan on using the 9lb pulley. What size injectors should I get. I will be replacing the pistons with 8.5:1 and the rods as well as a cam and head work in the future. Can I run on the stock injectors for now?? Thanks
Old Feb 9, 2005 | 08:35 PM
SungNamZ's Avatar
SungNamZ
Can't help you with the injectors, but I would probably suggest 1 step colder: NGK Iridium LFR6A1X-11.
Old Feb 10, 2005 | 04:26 PM
zcar03's Avatar
zcar03
bump
Old Feb 10, 2005 | 04:28 PM
MIAPLAYA's Avatar
MIAPLAYA
Agreed one step colder plugs and for injectors 380 CC injectors would probably be ok. If not you could for the 440CC injectors that come with the Greddy kit.
Old Feb 10, 2005 | 04:36 PM
zcar03's Avatar
zcar03
Ok so the 440cc should be enough when I do th einternal mods? Also is it essential to bump up the injectors for th e9 lb pulley
Old Feb 10, 2005 | 04:53 PM
MIAPLAYA's Avatar
MIAPLAYA
Honestly if you are only going to run the 9 lb pulley you are better off with the 380 CC PE injectors. They drop in and require no hacking. You wont need the 440s..and for your internals utilizing a blower a good idea would be to run 9.5:1 or 9:1.
Old Feb 11, 2005 | 06:35 PM
Carlitos's Avatar
Carlitos
I have six RC 440cc inj from my TT kit for sale. Brand new still in their package. $400
it works great with a TS reflash and your 9lb pulley
burglapfd
Dec 6, 2020 01:04 PM
35reilly
Sep 28, 2015 07:42 AM
