ABS and Slip lights coming on with Greddy
Old Feb 10, 2005 | 06:43 PM
Akira's Avatar
Akira
Default ABS and Slip lights coming on with Greddy
Once in a while my ABS, Slip, and VDC lights come on while driving. And it goes away after a while. Does anyone know why? It doesn't seem like it is hurting the performance. Anyone running Greddy kit having this?
Old Feb 10, 2005 | 08:00 PM
7 eleven's Avatar
7 eleven
I'm guessing you mean all at once? Has it been doing since you had the install? One possibility is that the steering column was reinstalled off one tooth. Is the steering wheel straight when you drive straight? If it's off more then a tooth or to the slip light will come on right away.
But if it's only off one it will come on only randomly or in turns when the VDC decides that it's off center. But that only lights the Slip and VDC lights. Not sure on the ABS
HTH,
Gary
Old Feb 10, 2005 | 09:07 PM
g356gear's Avatar
g356gear
Default Re: ABS and Slip lights coming on with Greddy
My car does this when I do a dyno session......and then is fine after I drive for a few minutes. Odd.
Old Feb 10, 2005 | 11:45 PM
Akira's Avatar
Akira
It happend when I did a burn out once, but that was when I was N/A. Now it happens more often since I got the TT. And I can't figure out what it is. And it's not the steering column. Weird...
Old Feb 11, 2005 | 05:50 AM
002-M-P's Avatar
002-M-P
Default Re: Re: ABS and Slip lights coming on with Greddy
Mine did it on the dyno too, but know where else. Weird..
Old Feb 11, 2005 | 08:46 AM
g356gear's Avatar
g356gear
With the VDC system I know the car has lateral G sensors as part of the control system. I think maybe the car gets confused when it is accelerating but not experiencing any G load on the sensors.
Old Feb 11, 2005 | 11:34 AM
t32gzz's Avatar
t32gzz
Mine stayed on all the time. I took it to Nissan and they reset the sensor triggering the problem and it was all good. They still charged be like $150, but the lights are gone.
Old Feb 11, 2005 | 12:14 PM
Enron Exec's Avatar
Enron Exec
I have that darn problem. Did they charge you because you are out of warranty?
Old Feb 11, 2005 | 08:25 PM
Alang's Avatar
Alang
The lights come on during dyno sessions because the front wheels are not spinning. The sensors detect that the rear wheels are spinning like mad, but no signal from the fronts makes the system think something is broken. Once the fronts start spinning again, the system resets itself.
This will also happen during long burnouts for the same reason.
Obadabot
Jun 18, 2023 11:31 PM
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
samansharif
Sep 25, 2015 12:31 PM
