Engine is READY ! just some ?'s
Old Feb 13, 2005 | 07:48 AM
GMADD's Avatar
GMADD
Default Engine is READY ! just some ?'s
It's done !
My engine build up is complete !
On monday I'm going to the garage and I need to know if I can drop the engine back in with the tubos installed or at least the manifolds installed.
Or should I wait for the CAS wire to arrive from the GB ?
is it easy to install the wire if my engine is back in place ?
Thanks !
P.S: Pics are on the way
Old Feb 13, 2005 | 07:50 AM
etx's Avatar
etx
You should be able to install it with the turbos on. You going from up top or bottom?
Old Feb 13, 2005 | 07:52 AM
GMADD's Avatar
GMADD
I'm droping it in from the top and I'm not sure if the turbos have enough space.
Old Feb 13, 2005 | 10:17 AM
002-M-P's Avatar
002-M-P
Turbos and manifolds can stay on, but wastegates must be off. Check out Sharif's removal pics and you can see what can stay on while it goes out/in. https://my350z.com/forum/showthread....hreadid=107045
Old Feb 13, 2005 | 11:32 AM
GMADD's Avatar
GMADD
Do you know if the engine bay of the Z is the same size as the G35 ?
Thanks !
Tasso-
Old Feb 13, 2005 | 11:34 AM
g356gear's Avatar
g356gear
Thanks !
Tasso-
Identical from the firewall forward.
Old Feb 13, 2005 | 02:17 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Turbos, manifold can stay in place....also connect the elbows to the turbo...those are tough to put on when the motor is in place.
Wastgates need to be off, becuase you cant get the tranny housing back on with them in place. Leave the downpipes off too.
The shielded CAS wire is easy to change when the engine is back in..dont worry about that for now.
You will just be unplugging the factory plug, and inserting the new plug and running a new wire back to the ECU through the firewall.
Congrats on the engine. Good luck
Old Feb 13, 2005 | 02:41 PM
GMADD's Avatar
GMADD
Thanks to all !!!
Pics will be posted monday night
Tasso-
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
