Stillen Stage 3 pulley
Old Mar 5, 2005 | 04:38 PM
ROGUE23's Avatar
ROGUE23
Default Stillen Stage 3 pulley
Hey Guys, How do you install the pulley and where does it go in?
Does it go on the supercharger or on the bottom?
Thanks.
Old Mar 5, 2005 | 06:07 PM
g356gear's Avatar
g356gear
Default Re: Stillen Stage 3 pulley
Thanks.
The pulley will be a smaller diameter one which replaces the one on the snout of the blower. You need a special puller tool to pull the pulley off of the snout once you remove the nut. I did the swap on my girlfriends Xterra SC to a smaller pulley...easy swap.
Old Mar 6, 2005 | 12:25 AM
Znitro's Avatar
Znitro
Default Re: Re: Stillen Stage 3 pulley
Sorry.... on the Stillen set up it is the top 6 rib pulley 5 min job!
Old Mar 6, 2005 | 08:23 AM
g356gear's Avatar
g356gear
Default Re: Re: Re: Stillen Stage 3 pulley
Well it looks like Stillen thought ahead a little then. I assumed they would be the same because they are both Eaton blowers.
Old Mar 7, 2005 | 03:35 PM
ROGUE23's Avatar
ROGUE23
Thanks for the info Guys. Stage 3 pulley looks much bigger than the one on there. Is this right??
Thanks again.
Old Mar 7, 2005 | 03:39 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Thanks again.
Im assuming stage 3 is more boost than stage 2, which on your s/c should be a smaller pulley. Are you sure your looking @ the correct pulley? BTW where in MD are you, Id love to run a Stillen s/c Z.....
Old Mar 7, 2005 | 04:09 PM
2003z's Avatar
2003z
the red one is the stage 3, the black is the stage 2. you can see the red is slightly smaller.
Old Mar 11, 2005 | 06:16 PM
ROGUE23's Avatar
ROGUE23
Stillen sent me a GOLD pulley and it is bigger than the original stage2 pulley,
I called them and they said it is the right size...?? I always thought higher boost pulley will be smaller. How about it?
Alberto I'm in Silver Spring.
Old Mar 11, 2005 | 06:40 PM
AmyCroft's Avatar
AmyCroft
Think about it - What if you had a one inch pully, and the belt is crank driven just as fast.....the little pulley would make many more revolutions per foot of belt...
Your Stillen rep needs a math lesson...
Cheers Amy -
Old Mar 11, 2005 | 07:38 PM
ROGUE23's Avatar
ROGUE23
Sales person at Stillen said "You need a bigger pulley to get bigger boost" I'm gonna have to call them again tommorrow. Any one here with pics of stage3 please post. Thanks.
Old Mar 11, 2005 | 08:07 PM
AmyCroft's Avatar
AmyCroft
Smile
The information is within this post - read again carefully - and open the link
to show the red pully.. the red pully is smaller Stage 3
The shaft of the blower will run faster ( more RPM's ) with a smaller pulley...
In Stillen 350z the crank pulley is not changed the Blower pulley is changed..
Rogue23 please roll a pencil and a beer can accross the table...
Cheers Amy -
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
