3 Things that will make you shoot yourself
Old Mar 7, 2005 | 06:59 PM
bruschijr's Avatar
bruschijr
Angry 3 Things that will make you shoot yourself
And the bronze metal goes to.....
Paying to get an EGT sensor welded in your test pipes... only to find out that you can actually scrape some of the weld off with your fingers....check out the air leak line on that...
The silver medal goes to....
Paying $6000 for a turbo kit... that uses crappy wastegates... BOOST LEAK anyone? Turbonetics here I come...
And the gold medal goes to...
Rusty bolts that snap inside your turbo... this was awful... it got stuck about 2/3 the way out turning it by hand... which has happened a few times... so i put the ratchet on... and... SNAP... I put less pressure on this bolt than any of the other ones... hope i dont have to get that drilled out.... probably will...
Hmm... yeah those things suck pretty bad....
Engineers ------> <----- Me
Girls at the beach -----> Me ------>
Old Mar 7, 2005 | 07:27 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Two words for ya....anti-seize compound on all the hot bolts and threads, and heat treat the hot parts.
Old Mar 7, 2005 | 08:53 PM
xxlbeerZ's Avatar
xxlbeerZ
Wasn't there some thread that says those gaskets leak because the holes aren't drilled through? (I believe reaming the hole or using shorter bolts fixes the leak)
Old Mar 8, 2005 | 11:22 AM
Sharif@Forged
Forged Performance
The stock Greddy gaskets used to be crappy paper gaskets. The newer kits have the thicker metal headgaskets, and no leaks.
Anthony had one of the earlier Greddy kits.
Old Mar 12, 2005 | 04:44 PM
accordfreak's Avatar
accordfreak
1) go to someone who knows how to weld
2) tial makes great wastegates but crappy gaskets.. go turbonetics gaskets
3) use grade 8 allen bolts from home depot. It's 10 time easier to unscrew and screw on and they never snap. I crossed threaded the bolt once on the turbo with that allen bolt and it wouldn't break if when i wanted it to. I had to cut it in half because i needed to take off the downpipe.
Tochigi_236
Sep 27, 2015 03:40 PM
