bov with vortech
Old Mar 11, 2005 | 05:05 PM
MCopare's Avatar
MCopare
Default bov with vortech
Anyone know of any bov's besides the Greddy type S that mount up to the flange on the vortech kit??
Old Mar 11, 2005 | 05:26 PM
booger's Avatar
booger
Dont get a BOV for your Vortech . We have a Bypass valve . I made that mistake the other day . I have a Greddy RS type BOV for sale in a week or so . When I get it back
Old Mar 11, 2005 | 05:31 PM
MCopare's Avatar
MCopare
really? I thought they were essentially the same thing. Would it be a huge benefit to recirc back into intake?
Old Mar 11, 2005 | 05:39 PM
booger's Avatar
booger
Alot of unnessesary pipping IMO . And then you would have to tune it for the extra air going in at idle and under vacuum
Old Mar 13, 2005 | 08:12 AM
Gman2004's Avatar
Gman2004
check it this thread https://my350z.com/forum/forced-induction/113491-dynoed-and-tuned-the-g-today-vortech-people-i-need-advice.html
Aron's sig says he is using a greddy s bov with his vortech. You might want to ask him how he got it to work.
Old Mar 13, 2005 | 08:16 AM
booger's Avatar
booger
Originally Posted by Gman2004
check it this thread https://my350z.com/forum/showthread.php?t=113491
I believe the ....the Greddy S type BOV has [2] vacuum ports . So it can be used as a BOV or a bypass valve
Old Mar 13, 2005 | 01:43 PM
teh215's Avatar
teh215
Does anyone know if there would be any problems moving the Vortech bypass valve from its stock position to after the intercooler, up closer to the MAF? I am planning on getting the Injen intake piping for the Vortech when/if it is ever released and I would like to move it. Not for any performance reason, just for looks.
Old Mar 13, 2005 | 01:49 PM
baptist's Avatar
baptist
The Greddy type S, is exactly the same in design as the Vortech BOV, its just a piston style BOV. I have it fitted on my car. I believe the other port is there to make the BOV function correctly, not as an alternative port. Bypass is just a term used on these valves. Bypass seems to be used as a term on supercharger kits.
I think the only problem may arise when trying to use one of the dual chamber style valves (i.e. HKS, Blitz etc).
Old Mar 13, 2005 | 02:23 PM
aron's Avatar
aron
The Greddy type-S is a direct fit and replacement, the vortech bypass valve and greddy type-s both work the same, no issues at all. Greddy type-s can hold up to 15lb of boost I believe.
Old Mar 13, 2005 | 02:29 PM
booger's Avatar
booger
why is the RS type any different ? It only has one port and only works as a BOV . It wouldnt open under vacuum , even when adjusted all the way out . Getting confused here .
Old Mar 13, 2005 | 07:43 PM
Gman2004's Avatar
Gman2004
How does it sound with the greddy type-s?
Old Mar 14, 2005 | 05:17 PM
aron's Avatar
aron
Sounds much better, a lot cleaner a crisp and still pretty loud...still some fluttering though when releasing under high load
Old Mar 14, 2005 | 05:44 PM
booger's Avatar
booger
How is the whistle ? Is it any louder...less . Thats the biggest problem I have with the Maxflow is the dam whistle
Old Mar 14, 2005 | 05:46 PM
freezeg35's Avatar
freezeg35
is this the one i need? Seems pretty cheap!
http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
Old Mar 14, 2005 | 06:03 PM
booger's Avatar
booger
yup....is a dam good price too .
Old Mar 14, 2005 | 07:22 PM
G352NV's Avatar
G352NV
Why are people replacing their BOV on this kit? Im installing my Vortech tomorrow and with all the posts about replacing the one that comes with the kit Im starting to think I should have bought a aftermarket. From the ones Ive heard in the video's seem like the Vortech one sounds good!
Old Mar 14, 2005 | 09:40 PM
freezeg35's Avatar
freezeg35
The reason is as booger stated, it whistles like a chevy pickup that is running on the brake squealers. You should not have to put air filters and stuff dense foam in them to quiet it.
Old Mar 15, 2005 | 07:29 AM
gspot35's Avatar
gspot35
Why would you want to intercool air that does not get used. On a warm day you are going to heat soak your intercooler as well as heat the entire system up a lot more. BAD IDEA IMHO. I think you will really regret moving the BOV post fmic. You might consider putting it right out of the blower.
g/l
Old Mar 15, 2005 | 07:33 AM
gspot35's Avatar
gspot35
He bought it...keep us posted freeze!
Old Mar 15, 2005 | 08:35 AM
teh215's Avatar
teh215
g/l
Good point, I didn't even think about the fact that the hot air will be soaking the intercooler.. D'oh. Thx
