APS TT + EGT and WB02 sensors
Old Apr 3, 2005 | 09:23 AM
Madelinot's Avatar
Madelinot
Default APS TT + EGT and WB02 sensors
Hi all,
I will be getting the APS TT kit very soon. In preparation for this, I have bought the Zeitronix kit, which include an EGT and a Wideband 02 sensor. I am planning on keeping the stock cats for now. The question I had was where should I mount the 2 sensors? The best option I was thinking about was to weld bungs to the turbine outlet casting (right after the turbos), which are made of cast iron. Is that possible? What do you suggest?
Thanks!
Old Apr 3, 2005 | 09:32 AM
g356gear's Avatar
g356gear
The EGT should have a threaded mount that you can drill and tap right into the exhaust manifold. You don't want to weld onto cast....very tough to do without cracking them.The wideband O2 bung should probably go onto the pipe section where the cats are...if you go to test pipes or aftermarket cats they can put an extra bung on when you order them .....for a small fee.
liqalu04
Jan 2, 2022 12:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
