Stock manifolds for S/T?
Old Apr 4, 2005 | 03:32 PM
failsafe306's Avatar
failsafe306
Default Stock manifolds for S/T?
I really like the idea of the single turbo (APS nearly went down the same path until we realized that CARB approval was not possible) though your comments regarding the stock manifolds not being subjected to heat and stress is simply not correct.
The stock 350Z manifolds are subject to the identical thermal and stress loads as any turbocharged engine and in fact would be more likely to fail prematurely as the cast iron for N/A manifolds applications is of a very different specification to that of cast turbo manifolds (turbo manifolds are cast in a ni Resist iron with very high nickel content approx 45% nickel and designed to cope with extreme exhaust gas temperature of around 1800 to 2000 F).
Exhaust manifolds on N/A engines are designed to cope with exhaust gas temperature of around 1400 F.....................N/A manifolds when ustilised in a turbo application are going to fail for sure..............it's simply a question of when not if.
Please don't take the above comments as criticism as this is not my intention and I believe that the single turbo approach is a very viable option if engineered to the required standard............it's just that the stock nissan manifolds will not cope (will fail it's only a question of time) with the high exhaust gas temperature in a turbocharged application.
Peter
APS
I came across this old quote from APS while researching my FI options. Now, please forgive me if this has been covered before, but doesn't the APS S/T kit use the stock Nissan manifolds? What has changed since this post to make the stock manifolds suitable for FI now? I'm concerned because up until I read this post, I was almost 100% for going with the APS S/T kit as soon as it came out.
Old Apr 4, 2005 | 03:35 PM
MIAPLAYA's Avatar
MIAPLAYA
Well after posts and posts of telling me and everyone the stock manifolds are GURANTEED to crack they finally actually LOOKED at the manfiolds and realized they are fine. The Stock manifolds are made of 409 Double Wall Steel and have less chance of cracking then your average aftermarket header.
Old Apr 4, 2005 | 03:37 PM
failsafe306
whew....
That's good to hear, thanks Miaplaya!
Old Apr 4, 2005 | 03:42 PM
MIAPLAYA's Avatar
MIAPLAYA
whew....
No worries...I don't know how long I argued that point with him and others and in the end he decides to use the stock headers too...go figure..... Sure they may not flow better then aftermarket headers but at least they'll last while. Thats one piece of info I actually got to hear from the mouth of a Nissan QC Engineer. 409 Double Wall Steel is better **** then you'll get from DC Sports.
Old Apr 4, 2005 | 05:39 PM
uplz4588's Avatar
uplz4588
so MIA what kinda power you getting w/ the turbonetics? and what RPM do you see full boost? i havnet seen anythreads about it installed... only one i know of is yours...
Old Apr 4, 2005 | 08:40 PM
redline350ZZ's Avatar
redline350ZZ
I second that...its hard to decide which kit to buy when all I know of is one install........
Old Apr 4, 2005 | 08:47 PM
xxlbeerZ's Avatar
xxlbeerZ
Hopefully in the next few weeks we'll get some unbiased reports (if the kit is actually selling).
MIAPLAYA has done a great job so far relaying all the info he can (awesome videos, pics, etc), but you can't really say he's a neutral source.
Old Apr 4, 2005 | 08:53 PM
MIAPLAYA's Avatar
MIAPLAYA
I'm making 386 RWHP at 8 PSI with 11:1 AFR from boost to redline. Full boost is at 4k rpms. (HP numbers are a Dynapack number)
Old Apr 4, 2005 | 10:15 PM
mchapman's Avatar
mchapman
Max boost @ 4000rpm with a 6600rpm redline = 2600rpm of full boost action.
When do the twins reach full boost? Around ~2300rpm??? (anyone know?) = 4300rpm of full boost action.
Old Apr 4, 2005 | 10:19 PM
AmyCroft's Avatar
AmyCroft
MIAPLAYA..
Congrat's on the numbers.... Looking forward to the Dyno Pictures...
any word on CARB certification?
Cheers Amy -
I guess the latest change in the smog law's are good news to you.
Old Apr 4, 2005 | 10:24 PM
MIAPLAYA's Avatar
MIAPLAYA
No word yet on CARB. I know that Turbonetics is actively researching it though. As soon as I know i promise you all will... Thanks for the congrats.
Old Apr 4, 2005 | 10:28 PM
APS's Avatar
APS
I did post that info some time back and to be frank it's still my view. I don't believe that the stock VQ manifolds will last for ever and a day at high power levels (with lots if expansion and contraction of the stock manifolds) and with the elevated exhaust gas temperatures associated with high horsepower, that said APS's decision to retain the stock exhaust manifolds was purely a cost consideration, it's that simple.
Nothing has changed in this time frame and no doubt the stock exhaust manifolds are not ideal for a turbo application though I suspect the stock manifolds will be durable for some time period depending on how the engine/car is used and how frequently and to what extent the exhaust mainifolds are heat cycled.
With this in mind APS is already developing a set of special turbo exhaust headers from a high grade stainless steel for the guys who will no doubt find the durablility limit of the stock exhaust manifolds over time, these will be available as an option in the not too distant future.
Peter
Old Apr 4, 2005 | 10:40 PM
redline350ZZ
Peter any time frame before we as customers can see an online install guide for the S/T kit.....??
Old Apr 4, 2005 | 10:55 PM
APS's Avatar
APS
That will be the very last part of the single turbo project to be completed by the engineering guys at APS though it should be completed by the end of April/early may all going to plan, is there something in particular that you would like to know?
There will be several new pics and more detailed information on the APS web site within the next 24 hours, I trust you will find this info very interesting.
These new pics will provide you with a good deal of information as to the ease of the APS single turbo fitment and will also go a long way to show you guys how not to over complicate a single turbo conversion, all good.
Peter
Old Apr 5, 2005 | 08:07 AM
redline350ZZ
Not to steal from this thread as this will be my last post....
I just like reading instructions and feel this will help in the decision process...
Old Apr 5, 2005 | 09:16 AM
bwzabodyn's Avatar
bwzabodyn
I have a question about aftermarket headers...
I currently am running the Pro-1 Topspeed headers on my car (an Auto G35) and I'm about 99% sold on your kit - how would these headers change the output of the kit? I still have the stock manifolds, so if it's recommended that I go back to stock, I have that option... what do you suggest Peter?
Old Apr 5, 2005 | 09:17 AM
MIAPLAYA's Avatar
MIAPLAYA
Well as long as the headers exit in the factory location they will fit fine. As for what it will do...that remains to be seen but it might help spool up a bit...
