Just received my Turbonetics KIT!
Old May 1, 2005 | 05:43 PM
  #161
Peking's Avatar
Peking
Originally Posted by MIAPLAYA
I looked at a friends owners manual who was one in a WRX. I tried to find it on Blitz USAs webpage but couldn't...sorry...
No problem, I kinda figured I would have to cross that bridge when I get there
Old May 1, 2005 | 06:02 PM
  #162
MIAPLAYA's Avatar
MIAPLAYA
Yeah it does kinda suck though. I mean I was able to find the HKS, Greddy, and Apexi instructions online and the only other one I like as far as settings and user interface was the Apexi but people have said they have seen problems with the Apexi not maintaining correct boost pressure every time so I went with the Blitz
Old May 3, 2005 | 04:32 PM
  #163
1 2 NV's Avatar
1 2 NV
Hey projectsherv, where are the vids/pics?!
Old May 9, 2005 | 07:35 AM
  #164
xluv2eatx's Avatar
xluv2eatx
how did you modify the BOV?! i got a kit on the way and i dont want a queef, i want a fart! details please....
Old May 9, 2005 | 07:59 AM
  #165
kcobean's Avatar
kcobean
You just gotta be VERY careful when you do this. Remember that you're venting 1000-1200 degree exhaust gas directly out of the wastegate into the under-hood atmosphere. If the venting occurs anywhere near the signal hose for the wastegate, you could end up with no boost control. I've haven't heard of this happening yet, but it would be a damn shame.
Old May 9, 2005 | 08:00 AM
  #166
MIAPLAYA's Avatar
MIAPLAYA
In a street set up there is really no major need to do this. There will not be any significant performance gains to be had by doing so. The car will be a bit louder but thats about it...
Old May 9, 2005 | 08:04 AM
  #167
kcobean's Avatar
kcobean
MIA, can you clarify where the stock wastegate normally vents? I'm guessing it's back into the exhaust stream? Is this physically done into the down pipe?
Old May 9, 2005 | 08:07 AM
  #168
MIAPLAYA's Avatar
MIAPLAYA
Yes it dumps into the downpipe from the turbo. The wastegate is divorced from the turbo and there is a discharge pipes that runs from the wastegate outlet to the turbo downpipe....
Old May 9, 2005 | 08:12 AM
  #169
MIAPLAYA's Avatar
MIAPLAYA
Heres a pic of the dump tube...
Old May 9, 2005 | 08:17 AM
  #170
kcobean's Avatar
kcobean
So that tube runs between the output side of the wastegate and some flange on the downpipe?
Old May 9, 2005 | 08:23 AM
  #171
MIAPLAYA's Avatar
MIAPLAYA
Right....
Old May 9, 2005 | 08:25 AM
  #172
kcobean's Avatar
kcobean
Right....
Do you happen to have a picture of either the turbo (w/wastgate) or the downpipe out of the car, like the dump tube pic above? Not being too familiar with the physical characteristics, I'm envisioning that the WG is bolted to the side of the snail?
Old May 9, 2005 | 08:28 AM
  #173
MIAPLAYA's Avatar
MIAPLAYA
Here you go...
File Type: jpg
Old May 9, 2005 | 08:29 AM
  #174
MIAPLAYA's Avatar
MIAPLAYA
Here you go...
FYI thats a pic from the test car...your kit will have a polished SS pipe//
Old May 9, 2005 | 08:37 AM
  #175
kcobean's Avatar
kcobean
I see. So in this picture, I can see the dump tube behind the heat-shielded signal hose. This dump tube runs up to the the waste-port on the turbo and the gate itself is bolted to the downpipe? I can't tell from the picture, but what is the downpipe connecting to just to in this picture?
Old May 9, 2005 | 08:39 AM
  #176
MIAPLAYA's Avatar
MIAPLAYA
No the pipe the wastegate is connected to is the turbo feed pipe. The dump tube goes UP to the turbo downpipe which starts higher up at the exhaust outlet flange of the turbo...
Old May 9, 2005 | 08:58 AM
  #177
kcobean's Avatar
kcobean
Ah....So the wastegate is actually venting pressure from the feed pipe rather than from the turbine housing based on a pressure signal (or is it a vacuum signal). Where is the control hose connected to on the intake side of the system?
Old May 9, 2005 | 09:14 AM
  #178
MIAPLAYA's Avatar
MIAPLAYA
The control hose is ran from manifold pressure...
Old May 12, 2005 | 02:37 PM
  #179
xluv2eatx's Avatar
xluv2eatx
man...im confused! ok, so what do i got to do to make a loud-*** "pppsssshhhh" sound when i shift or let go of the gas after full throttle. let me know if its better to modify or buy a new aftermarket BOV. remember....."ppppssssshhhh!!!"
Old May 12, 2005 | 02:50 PM
  #180
MIAPLAYA's Avatar
MIAPLAYA
You don't have to do anything. The BOV that comes with the kit already vetns to atmosphere and will make that nice PSHHHHHHHHHHHH!!!!!! sound when you shift under pressure...
