Vortech install question #2
Old Apr 24, 2005 | 10:33 AM
Phaneom's Avatar
Phaneom
Default Vortech install question #2
When connecting the the hose coming off the FMU to the hose leading to the engine how much play is in the connection? When I clip it together the two pipes move around a little. Is there a gasket inside that stops it from leaking? Or should it be really tight with no movement at all?
Thanks
Old Apr 24, 2005 | 10:35 AM
Phaneom's Avatar
Phaneom
Just to clarify: This is steel (male) connector that connects into the stock (female) connector.
Thanks
Rob
Old Apr 24, 2005 | 12:23 PM
booger's Avatar
booger
Rob Not sure what connection your talking about . I never had to fool with mine and I have a return system now . So I cant help . Maybe if you post a pic some one can get a better idea of what connection and be able to help
Old Apr 24, 2005 | 01:16 PM
Phaneom's Avatar
Phaneom
Here are the pictures of the connection that I am talking about. There isn't a lots of movment, but it is not really really tight. I know it will never pop out (clipped in good), but I'm just wondering it it will leak around the sides, since it can spin and move a little. I guess if I don't find the answer I'll just find out when I start the car , and change the type of connection.
Attached Thumbnails Vortech install question #2-p1.jpg   Vortech install question #2-p2.jpg
Old Apr 24, 2005 | 01:21 PM
booger's Avatar
booger
Ok ..thats what I thought you was talking about . Im pretty sure there is an O-ring on the end of the male fitting . I think the preasure from the pump seals the fitting , so it will not leak . Some one correct me if Im wrong on how that fitting works
Old Apr 24, 2005 | 01:54 PM
Phaneom's Avatar
Phaneom
Thanks Booger, you have been lots of help.
Old Apr 24, 2005 | 02:50 PM
teh215's Avatar
teh215
See my response in your pics thread.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
