installing oil temp gauge for TT kit
Old Apr 28, 2005 | 07:30 PM
Zivman's Avatar
Zivman
Default installing oil temp gauge for TT kit
Anyone done this without drilling an oil plug or pan? Was thinking I could possibiliy use a Greddy Oil Filter Block Adapter. I attempted a search on this, but didn't find anything. Anyone know of an aplication for the Z? If not, what's the easiest and safest way to install the sender unit?
Old Apr 28, 2005 | 07:41 PM
narkotic's Avatar
narkotic
You do know that most FI setups feed oil from a tap that is already in the pan right? There is a sensor on there for your 350z to measure pressure. I don't see why you can't tee off of that to measure the oil temperature.
Old Apr 28, 2005 | 07:50 PM
Zivman's Avatar
Zivman
I thought about that, but wasn't sure if that was doable. A friend of mine had a heck off a time running his gauge of a similar setup on his car. Just no space for him to fit it in (not a Z)
Thanks
Old May 6, 2005 | 12:17 PM
gringott's Avatar
gringott
I ordered the universal greddy oil adapter. Will post how it worked. Others have used it.
Old May 6, 2005 | 12:31 PM
G3po's Avatar
G3po
Default oil temp
If you have or add TTs they are each fed by a high psi pressure line. You should be able to place a tee , between were the new line taps into the lower block around the oil filter. The turbos also drain back into the oil pan, gravity feed, but I wouldn't put the sensor there.
Old Mar 30, 2010 | 12:26 PM
thekinn's Avatar
thekinn
Default Oil temp gauge - n/a Z - sensor/sender location?
Sorry to bump an ancient thread, but, my searches have come up a bit empty so far. I am a noob to adding gauges.
Looking to install an oil temp gauge in my N/A 06 Z. I'd prefer a drain-plug type adapter to drilling into the pan for the sensor. Are these readily available?
Is this what I'm looking for - (correct size/pitch unknown at the moment)?
http://www.customcarscentral.com/gdy...all-makes.html
Old Mar 30, 2010 | 12:33 PM
Nealoc187's Avatar
Nealoc187
to get accurate oil temp readings the sensor needs to be submerged in the oil, not in a passage or adapter.
Old Mar 31, 2010 | 06:47 AM
psychoballistic's Avatar
psychoballistic
+1 Could not have said it any better myself.
Old Mar 31, 2010 | 07:11 AM
RandomHer0's Avatar
RandomHer0
Run the AAM spacer, it has a place for a temp probe to be threaded in.
http://www.alteredatmosphere.com/mm5..._Code=350Z_ENG
Old Apr 1, 2010 | 04:25 AM
thekinn's Avatar
thekinn
- Thanks for the replies and the link. I now have a better idea of what it will take to get this mod done.
Old Apr 1, 2010 | 04:55 AM
JasonZ-YA's Avatar
JasonZ-YA
Do not get that adapter...........the drain plug and sensor will point downward and if you ever hit anything and that oil temp sensor breaks off ---- there goes all your oil...
use a spacer like they mention.....
OR
Remove your pan (or obtain an extra) and have the oem pan taped and welded with a bung:
https://my350z.com/forum/engine-and-...sor-mount.html
-J
SharX59
Sep 27, 2015 09:23 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
