What if you miss a shift with FI
Old May 8, 2005 | 12:29 PM
JonathanG35's Avatar
JonathanG35
Default What if you miss a shift with FI
Suppose you miss a shift with FI and bounce off the rev limiter? Is this disasterous for the engine? Is there a way to cut off all boost after say 6900 rpm and have a 7100 rpm so even if you hit the limiter you wont get a fuel cutoff situation under boost?
Old May 8, 2005 | 02:05 PM
teh215's Avatar
teh215
You should be OK if you're using a S/C because the bypass valve opens when you let off of the throttle. What are you using?
Old May 8, 2005 | 06:47 PM
JonathanG35
I am not fi yet. I hit the rev limiter enough that i need some way to not blow my engine if i hit the rev limiter. Usually i hit it in a bad shift scenario or in a sharp turn if i break traction and then the revs fly up and tach out.
Old May 8, 2005 | 07:00 PM
ZRAYGO's Avatar
ZRAYGO
Your blow off valve will make thi sloud a$$ noise....
Old May 8, 2005 | 07:31 PM
350G's Avatar
350G
Did it once and no big deal . . . I wouldn't recommend it very often though
Old May 8, 2005 | 11:22 PM
phunk's Avatar
phunk
CJ Motorsports
i bang off my rev limiter repeatadly several times a day :shrug:
during burnouts, 180s, donuts, and any time i floor it in 1st, 2nd, or 3rd... sometimes ill let it bang a couple times when racing so the tires can catch up before I shift so I dont fall out of the powerband in the next gear... but then again maybe thats why my track times suck for all the power im making!
Old May 10, 2005 | 05:03 AM
one3502nv's Avatar
one3502nv
I do it "by accident" all the time... I get really nice 10" flames out of my exhaust!! looks cool at night !! hehe
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Jambo016
Sep 16, 2016 01:08 PM
