Turbonetics Install Complete and dynoed!!
Old May 29, 2005 | 08:15 AM
  #221
MIAPLAYA's Avatar
MIAPLAYA
Thumbs up
Originally Posted by GQ 350z
The turbonetics kit is such a bargain for what it entails. I hope to have it by January! =(
Agreed. Possibly one of the most complete kits on the market and for a outstanding price point...
Old May 29, 2005 | 10:09 AM
  #222
SirJonnyWispit's Avatar
SirJonnyWispit
Im still hoping my kit shows up this week. Im ready to get it put on here and shred some rear tires!
Old May 29, 2005 | 01:01 PM
  #223
Phatmitzu's Avatar
Phatmitzu
Originally Posted by MIAPLAYA
You could take it Turbonetics and have it flashed there if you want but Technosquare is not doing the reflash. Turbonetics bought the hardware to perform the flash at Turbonetics and that is where the ECUs are being flashed...
The reflash should not take more than an hour correct? Im planning on dropping my car off to the shop in the early morning and take the ECU to Turbonetics for reflash while they install the turbo. BTW, how long is the installation for the turbo? appox.
Old May 29, 2005 | 01:26 PM
  #224
MIAPLAYA's Avatar
MIAPLAYA
Usually install takes 8-10 hours... Reflash takes about 45 minutes to an hour.
Old May 29, 2005 | 01:46 PM
  #225
cloudy's Avatar
cloudy
8-10 hours only with someone who has installed it before? What about a shop, lets say like Intense Motorsports where their speciality is Turbo's and stuff, but they have never installed a Turbonetics kit. How long would it approx take em?
Old May 29, 2005 | 02:00 PM
  #226
MIAPLAYA's Avatar
MIAPLAYA
Same time frame....it took a shop I am familiar with but that had never installed a Tnetics kit about 11 hours to install it with gauges...
Old May 29, 2005 | 02:20 PM
  #227
tabrizio's Avatar
tabrizio
MIAPLAYA where did you get your kit installed?
Old May 29, 2005 | 02:22 PM
  #228
MIAPLAYA's Avatar
MIAPLAYA
At Turbonetics...
Old May 29, 2005 | 08:18 PM
  #229
xxlbeerZ's Avatar
xxlbeerZ
Anyone have a dyno or boost graph yet (sea level)?
Old May 30, 2005 | 05:47 AM
  #230
taurran's Avatar
taurran
I should by next week. All of the newer dynos I have seen recently have been SAE corrected.
Old May 30, 2005 | 08:00 AM
  #231
kcobean's Avatar
kcobean
Even dyno runs done at Sea-level have to be SAE corrected to a standardized temperature and pressure don't they?
Old May 30, 2005 | 08:58 AM
  #232
350zWarz's Avatar
350zWarz
yep
Old May 30, 2005 | 09:04 AM
  #233
taurran's Avatar
taurran
Ahh. Well wouldn't the higher the correction typically mean a larger margin of error? From what I've seen of high altitude tests is dynojet typically has a tendency to over correct.
Old May 30, 2005 | 09:08 AM
  #234
kcobean's Avatar
kcobean
I'm no expert, but I would imagine you're correct. The more a number has to be corrected based on mathematical formula, the less accurately that number will reflect the real world results, especially given that the math can't possibly apply accurately to every car.
Old May 30, 2005 | 11:46 AM
  #235
SpeedDreamTuner's Avatar
SpeedDreamTuner
I've dynoed at sea level, and the SAE numbers were only .7 off...
Old May 30, 2005 | 11:56 AM
  #236
taurran's Avatar
taurran
Good to hear. Do you know what effect (if any) that humidity will have on dyno results? I was thinking about this the other day. It's starting to get hot and humid down here at this time of the year and I'm not sure what numbers to expect.
Old Jun 3, 2005 | 09:47 AM
  #237
Phatmitzu's Avatar
Phatmitzu
Originally Posted by kcobean
It alters the fuel and timing maps to account for the increased airflow, as well as raise the rev limiter and remove the speed limiter.
Just thought of it right now...it doesnt include the 100% WOT fix?
Old Jun 3, 2005 | 09:56 AM
  #238
Turbonetics's Avatar
Turbonetics
our flash does address the wot issue. i read in an earlier post of yours about going to Techno direct... i am sure they would flash for you but i am also pretty sure they will charge you...we include the cost of the flash as well as thr freight in your purchase price of the kit.
Brad
Old Jun 3, 2005 | 10:01 AM
  #239
Phatmitzu's Avatar
Phatmitzu
Brad
Oh ok.
Thanks for the fast reply. Going to Techno wont be the issue anymore then, cuz I just ordered your kit yesterday....
I'll just take my ECU to you guys for the reflash when the kit gets here.
Old Jun 3, 2005 | 10:05 AM
  #240
Turbonetics
Oh ok.
Thank you for the purchase!!! you will not be dissapointed...the rush of boost is like no other.
Brad
