Turbonetics Install Complete and dynoed!!
Originally Posted by kcobean
Do you know if the T-netics reflash turns off the O2 sensor function? MIA said that the SES light should NOT be on after the install of this kit, so it sounds like it does, but it would be nice to know for sure. I'd hate to have to keep resetting the ECU to turn it off if it's going to keep coming on. Thanks.
Originally Posted by MIAPLAYA
It will not Turbonetics is using a trick that I first learned about in the Spec V world to solve the O2 sensor SES issue. My car has it applied and like I said I do not have an O2 sensor code... Basically you add some drilled out spark plug non-foulers to the O2 bungs.
Originally Posted by Gman2004
I have this on my car as well....it works! Before the non foulers I drove around for almost a year with that damn f'ing SES light....so annoying!
It will not Turbonetics is using a trick that I first learned about in the Spec V world to solve the O2 sensor SES issue. My car has it applied and like I said I do not have an O2 sensor code... Basically you add some drilled out spark plug non-foulers to the O2 bungs. It ends up basically spacing the probe of the rear O2 sensors out about 2". By doing this you take the O2 probe just far enough out of the exhaust stream so that the change it is looking for in the lean rich signal is read correctly. Its a relatively simple mod and works well on various Nissan motors even those with a wideband O2. These are pre-welded in the bungs on all Turbonetics kits....bottom line=no O2 SES light.
Originally Posted by taurran
Hey Speed Dreams, are you running the Turbonetics ST with a Kinetix V4 plenum? If so, any issues? I'm planning on using my v4 with the kit. I don't think there will be any problems, just want to make sure.
Originally Posted by MustGoFastR
How about on '03 cars? How does the catless kit deal with the O2 sensors and avoid tripping the CEL? Does the standard reflash not shut them off or is there something else working here? I'm not too familiar with how our cats/sensors/ECM work/communicate, so the more info. on this I can get prior to making a decision, the better. I just want it to be able to pass the inspection process that I described above.
The best thing to do is install the Turbonetics down pipes with high flow cats, that's what I will be doing.
Originally Posted by SpeedDreamTuner
The V4 seemed more noisey, I switched back to the stock and it liked it better.
heeh. So it DID work? I'm not really concerned with what noise it makes, I'm just concerned with what works and what doesn't. As long as the thing doesn't crack or spring leaks under stock boost, then I'll continue to be confident that I can use mine with the kit.
The reflash would be capable of turning them off {O2 sensors} but most tuners will not due to liability issues. Simulators will not help you pass emissions, they just fool the ecu that exhaust gases are ok.
If I am reading this correctly as well as what MIAPLAYA said above, the kit comes set up to fool the O2 sensors and subsequently the ECM, correct? Thus no CEL and nothing out of the ordinary as far as the ECM is concerned, right? If this is the case, I think it'll be fine here in Houston, as all they do for OBDII inspection is jack into the OBDII port and see if everything is kosher according to the car's computer; they do no physical sniffer test. Am I missing something?
ill be installing the turbonetics kit next week and have boost and a/f gauges sitting here waiting to go in... since the reflash omits the 02 function what will my gauge do? anything?? or did i wasted money on it? thanks
its a defi d-gauge.... i know i know its not accurate for anything and "just a light show" but will it even show anything at all?? its a needle type that would normally bounce back and forth just to look cool... will it do anything with the reflash or is it just going to sit there? if it is its fo sale never been opened! 52MM black face amber numbers, matches the stockers perfectly
yea im with you now. i thought all 4 were modified. i see all these posts about ses lights and wonder why ive never had one come on and ive been running helix test pipes with the injen true dual for 6 months now.. am i just that lucky???
BTW i work at infiniti and can post any kind of service pages we need for a g35 coupe all years... most of it will apply to our 350's also. just letting you guys know i will help when needed... just PM me if you need something and ill get back shortly
