The No BS APS TT Thread
Old May 14, 2005 | 05:09 PM
Z33Concept's Avatar
Z33Concept
Originally Posted by Zcool
My APS TT was in stalled in Dec. '04 by Brainstorm in L.A. when I had 7,000 mi on my '04 roadster. I now have 12,000+ mi with no major problems. I have Helix test pipes, Nismo exhaust, Nismo wheels, Michelin Pilot Sports, Tein Flex with EDFC suspension and Hotchkis sways. Internals are stock as well as clutch. Dynojet tested 414 rwhp at 9.0 psi tuned by ZCarGarage for 91 octane.
I haven't been to a drag strip yet but I have done 2 days of road racing at Thunderhill (NorCal) and had a blast. If money isn't too much of hang up I strongly recommend the APS TT kit for instant 400+ HP.
You have 414 to the wheels and Ur stock clutch doesn't slip??
Old May 14, 2005 | 08:01 PM
Zcool's Avatar
Zcool
So far, so good.
Old May 15, 2005 | 04:57 AM
bullseye's Avatar
bullseye
(414rwhp) + (stock clutch) + (1 trip to the drag strip) = new HD clutch + light flywheel
Old May 15, 2005 | 08:51 AM
mystik_350z's Avatar
mystik_350z
for the 2 that are doing 11's on your aps tt kit, how many pounds of boost are you taking these runs at?
Old May 15, 2005 | 01:41 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
Z33Concept....did Roshan hadle your car over there at Brainstorm?
Also I too am curious what lbs of boost these 11 second guys are running.
Old May 16, 2005 | 01:27 PM
barthelb's Avatar
barthelb
Master
I would say you can do it on 8 maybe 7.5 psi if your real good. I did a 1.998 60' ft
12.40
115mph on street tires.
I haven't had luck launching in the Drag radials, I seem to be babying to much. So Im more than confident my car can hit 11's. And im not a pro!
Old May 16, 2005 | 04:45 PM
one3502nv's Avatar
one3502nv
I ran a 12.10@ 114 @ 6lbs and a 11.60@119 with 9lbs- STOCK BLOCK!!
Old Jun 2, 2005 | 07:18 AM
zman2's Avatar
zman2
bump for very informative posts.
Thanks to all
Old Jun 2, 2005 | 08:11 AM
tonio's Avatar
tonio
internal engine mods
None
other mods
Water Injection/Test Pipes/Nismo Exhaust/ RPS Clutch &Flywheel (highly recommended)
tuned or used "out of the box" set up
out of the box tune
RWHP
406whp
RWTQ
389rtq
where installed/tuned
Z1 Motorsports in Carrollton, GA this is their 5th or 6th APS install and I think one of the first completed G35 APS installs in the states if you dont include APS testing their system. Z1 Definitely knows what they are doing.
price for installation/tuning
I had a bunch of other stuff done all at the same time so my final bill is higher than what it usually would be
miles on kit
20 of the best miles I've driven in my life and counting
other comments
My car is hitting 10psi with test pipes and nismo exhaust. Before the car was obnoxiously loud which was cool at first but now I like how quiet it is. Everything is perfect, hearing the turbo's spool up is unreal as well as the performance. If this car came from the factory like this I could easily see paying $60-$70k just for the performance.
Old Jun 2, 2005 | 08:12 AM
Speedracer's Avatar
Speedracer
Okay....so what exactly is the out-of the box boost level set at?
Old Jun 2, 2005 | 08:13 AM
Lorca@Z1's Avatar
Lorca@Z1
My car is making slightly less power at 8.5 PSI, but it has been to the strip three days now (about 30 runs) and suprisingly the clutch is holding up fine. Best '60 1.79, best ET 12.44, best MPH 113.
Old Jun 2, 2005 | 08:16 AM
Lorca@Z1's Avatar
Lorca@Z1
Generally 8.5, but test pipes and full exhaust often raises this to 10 PSI.
Tony,
Glad to hear you are enjoying your car. Careful on these damn wet roads
Old Jun 2, 2005 | 08:36 AM
one3502nv's Avatar
one3502nv
Tony,
I was only seeing 7 lbs with the base 91 map on my car and now we tuned it forabout 9lbs and we see up to 10 on the road... And thats with cat pipes and dual exhaust for the whole time....
Old Jun 3, 2005 | 03:39 PM
ReavTek's Avatar
ReavTek
Tony,
So test pipes and full exhaust will automatically raise the boost level? If so, how can we lower the boost? I want to run it at stock boost (6-6.5 PSI) since I have stock internals. At stock boost is this safe or should rods be replaced at the very least?
Old Jun 3, 2005 | 05:26 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Sorry for the off-topic, but what tires/wheels were you running on the drag strip.? Stock LSD or aftermarket? Nice 60ft times...BTW.
Old Jun 3, 2005 | 06:46 PM
nickgundara's Avatar
nickgundara
Sorry for the off topic post, but I think the guys on this thread can answer this question best.
I currently have a Greddy EVO 2 exhaust and Stillen test pipes. Do you think I will benefit from changing over to an APS exhaust and test pipes when I install my APS TT?
Thanks, and sorry again for the off topic.
Old Jun 3, 2005 | 11:45 PM
350ed's Avatar
350ed
Professional
Changing test pipe manus will get you nowhere. The exhaust change might net you some but I doubt it's worth it. Spend it on a new radiator or oil cooler...
Tochigi_236
Sep 27, 2015 03:40 PM
