Emanage Ignition Harness
Old May 17, 2005 | 03:53 PM
Badmonkey's Avatar
Badmonkey
Default Emanage Ignition Harness
Does anyone have a wiring diagram for the emanage ignition harness? Greddy claims that it will not work on our cars. I know some forum members are using it, however.
Old May 17, 2005 | 04:11 PM
Gman2004's Avatar
Gman2004
Here you go. Dont forget the diodes. Radio shack PN 1N5401.
http://www.datavibe.net/~etx/z33_ignition%20install.pdf
Old May 17, 2005 | 04:46 PM
Badmonkey's Avatar
Badmonkey
I see that this diagram and Greddy's manual contradict each other. The Greddy says the inputs are the white striped wires and this diagram shows the inputs as the black striped wires. Also, Greddy claims that I have to wire the cylinders per firing order per channel. Does anyone know who this Derek is? I would like to see how the system is working. I plan to hook this up before my J&S Safeguard. I know there is redundancy, but I get the tunability of the emanage and the safety of the safeguard.
Old May 17, 2005 | 04:49 PM
Gman2004's Avatar
Gman2004
I found this diagram on this site when my shop tried to call greddy and they would not give them support. My shoped mentioned to me that the instructions had some wires backward. I think the ones you mentioned.
Here are some old thread on wiring this harness.
https://my350z.com/forum/showthread....ss+for+emanage
Old May 17, 2005 | 08:19 PM
narkotic's Avatar
narkotic
Kind of off topic, but why is it only the E-Manage that fries coils when the key is left in the 'on' position, and not any other piggy back ignition retardation solution?
i.e. splitsecond, j&s, unichip
Old May 17, 2005 | 10:34 PM
phunk's Avatar
phunk
CJ Motorsports
who actually HAS fried a coil? Anyone?
Old May 17, 2005 | 10:42 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
my vote... the fried coil deal is a myth
Old May 18, 2005 | 04:38 AM
mcderns's Avatar
mcderns
No fried coils here.
Old May 18, 2005 | 08:23 PM
narkotic's Avatar
narkotic
There were a few people that fried them, I remember sharif replying to a few of those threads back in the day. I know im not imagining things! hm..
Old May 18, 2005 | 08:58 PM
theking's Avatar
theking
Just use John's(J&S) schematic. It's right on the money. You won't have to worrry about frying coils if that is what's firing the coils. That's the exact setup that's going on mine. I'm even doing a TS reflash. I'm building another engine so I have the J&S and emanage ignition harness to see how far I can push the stock engine. Mine is being done next week so I'll be able to comment on this much better then.
Alan
Old May 19, 2005 | 12:02 AM
John at J&S's Avatar
John at J&S
Alan:
I have your stuff ready, but can't find your shipping address. Please email or PM.
Thanks
John
Old May 19, 2005 | 03:39 AM
luanda's Avatar
luanda
Had the harness on for 6K / 5 months - no problems yet.
Old May 19, 2005 | 02:11 PM
theking's Avatar
theking
I did both just in case.
Originally Posted by John at J&S
Alan:
Thanks
John
Old May 19, 2005 | 08:47 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
isn't the purpose of wiring in the diodes with the ignition harness to prevent frying the coils??? i have kept my key in the "on" position for several seconds, several times
TODD
Old May 19, 2005 | 08:49 PM
Gman2004's Avatar
Gman2004
TODD
I have keep mine in the on position for more than 30 seconds while resetting the ECU with the TS method....no problems yet...Knock on wood. I was told it had to be several minutes to fry the coils.
Old May 19, 2005 | 09:59 PM
narkotic's Avatar
narkotic
Yeah, that was it. Don't listen to the radio when the car is off (in the on position). A few people have fried their coils this way, only with the e-manage. This brings me back to my original question, why? (Yes they had the diodes installed)
Old May 20, 2005 | 12:11 AM
John at J&S
The Split Second box intercepts the cam and crank sensor signals, so it doesn't interfere with the coil drive signals.
The J&S intercepts the coil drive signals, but passes the stock signals through to the coils, unless retard is needed. Software in the unit turns the coils off if no triggers are present.
I have read that the Greddy drivers are not able to completely turn off the coils. The diodes drop the output enough to turn them off.
Don't know about the stall condition. Maybe Greddy software designers forgot to turn off the coils.
Easy enough to check with a scope or voltmeter. Check each coil wire in turn: key on, note voltmeter, then quickly turn off the key. Hopefully, all coil drive signals would be zero volts in the stall condition.
Old May 20, 2005 | 01:06 PM
Badmonkey's Avatar
Badmonkey
John, So if I hook up the emanage and run it through your system last, then I should not have a coil issue, right? This is the setup that I am currently installing. Do I need the diodes for the emanage AND the diodes for the safeguard? I have been running the safeguard for a week now and it is working perfectly. I had spoke to you about possible problems. I found the only problem was me reading the schematic properly. Thanks for the offer of coming to Burbank and help out.
Old May 20, 2005 | 02:57 PM
John at J&S
Mr. BadMonkey:
I would try installing the emanage between the ECU and the J&S.
You shouldn't need diodes on the emanage, but leave them on the J&S if it's an earlier unit (pre 8/04).
Unless the emanage has been preset for 350z, you might have to open it up and move the internal switches and jumpers.
ACP tried to make the two units work together, without success. Let me know if you have trouble, and I might make the trip to Burbank after all.
Old May 20, 2005 | 03:21 PM
narkotic's Avatar
narkotic
Thank you john that answered my question. Was just looking for something a little more technical
