Why is my boost gauge reading so high?
Old May 24, 2005 | 12:10 PM
HankVQ's Avatar
HankVQ
Default Why is my boost gauge reading so high?
Hey guys I'm new to forced induction so maybe someone can shed some light. So I just installed my Stage 3 Stillen supercharger. This is the first forced induction install that I have attempted so minus a few minor hangups everything turned out better than I could have hoped for. Thanks to Mike (2003z) for helping me sort some things out. Car pulls pretty damn hard now.
Now onto my question. When I go WOT my Defi boost gauge is reading like 14 psi. Now I know superchargers are a different animal than turbos but I was under the impression that with the 7 lb. boost pulley I would see 7 psi. on the gauge. Can someone clue me in? Thanks.
Old May 24, 2005 | 02:15 PM
teh215's Avatar
teh215
Where is the gauge connected to read the boost?
Old May 24, 2005 | 03:08 PM
UnderPressure's Avatar
UnderPressure
Here's a test case. With the key in the run position and engine not running, what does the gauge read. If it reads anything other than zero the gauge is not calibrated.
Is this a mechanical or electric boost gauge?
Assuming the gauge is calibrated correctly, you are actually seeing 14lbs. Which poses different problems altogether.
Old May 24, 2005 | 03:19 PM
HankVQ's Avatar
HankVQ
It's a Defi mechanical and when the key is in the on position it reads right around 7 psi.
Old May 24, 2005 | 03:26 PM
MIAPLAYA's Avatar
MIAPLAYA
Your gauge is not correct. It should read zero with the engine off and key switched to on...
teh215's Avatar
teh215
That's not good
Old May 24, 2005 | 04:43 PM
UnderPressure
We have a winner, you have a bad gauge. Look @ the paperwork that came w/ the gauge for warrenty issues. Good luck.
Old May 24, 2005 | 04:49 PM
HankVQ's Avatar
HankVQ
Thanks for your help, will do.
Old May 24, 2005 | 08:45 PM
350G's Avatar
350G
Sorry to hijack the thread, but I just love Will's tact . . . *LOL*
Old May 25, 2005 | 06:55 AM
UnderPressure
You miss me, don't you.
I'll be back in Lex sometime around June 6th.
Old May 25, 2005 | 07:11 AM
Gman2004's Avatar
Gman2004
I have a defi d and after two months of use it became uncalibrated. It would read 2psi when the key is off. I just bought a new one and will send the bad one back for warranty and then resell it in the classifieds when they send me a new one. I will lose about $30 but I won't have to wait for my new gauge.
EnjukuRacing
Sep 30, 2015 06:55 AM
codek
Sep 28, 2015 03:03 AM
