Clutch recommendations?
Old May 28, 2005 | 05:45 PM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
Default Clutch recommendations?
Hey guys I am going to start my engine build-up next week and need suggestions on which clutch to get. Something that will fit my budget but still very good for my setup. I want the ATS twin disc, but thats way out of my budget. I was thinking of getting the JWT clutch and flywheel combo but needed your guy's input. click my sig for my mods. Thanks ahead.
--Tim
Old May 28, 2005 | 06:29 PM
xxlbeerZ's Avatar
xxlbeerZ
From what I've read a lot of people recommend Clutch Masters for a cheaper clutch.
Old May 28, 2005 | 06:55 PM
002-M-P's Avatar
002-M-P
I'm still debating about the ATS Twin Disc as well because of the price, but as alternate choices I have two that I am considering alot. Both options are with the JWT flywheel and then the Clutchmasters Stage 3 or 4 or the RPS Max Series 6 puck.
The JWT flywheel was built to accomodate 350z clutches and 300zx tt clutches, so SGP racing sells a JWT flywheel and RPS Max Clutch combo for about 850 with the street disc or 900 with the 6 puck disc.
Old May 28, 2005 | 09:00 PM
tonio's Avatar
tonio
I have the RPS Max Clutch and love it, and I think its cheaper than the ATS.
Old May 28, 2005 | 09:05 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
--Tim
yah..the ats twin disc is pricey..but i love it...contact sharif and see what else he has that may be cheaper and comparable
Old May 28, 2005 | 09:59 PM
cquence 350 [Z]
okay what would be better?
1. JWT clutch and flywheel combo
2. JWT flywheel / RPS clutch
3. Clutchmasters Stage 4 and flywheel
4. Others like ACT, Etc.
Old May 28, 2005 | 10:08 PM
Z BOY's Avatar
Z BOY
the answer is...it all depends upon how much hp/tq you plan on making. the jwt clutch can hold up to 550ftlb, i believe. if you plan on making more, you'll need a stronger clutch. do a search and edumacate yosef
Old May 29, 2005 | 10:04 AM
002-M-P's Avatar
002-M-P
rps max clutch w/ street disc is suppose to hold 590 ft-lbs and the rps max clutch w/ puck disc is suppose to hold about 700 ft-lbs or torque and still be drivable..
Old May 29, 2005 | 11:21 AM
Jaki's Avatar
Jaki
I have the JWT clutch and flywheel combo and I'm really happy with it.
Old May 29, 2005 | 08:24 PM
amolaver's Avatar
amolaver
what about something in the 400whp range? clutchmaster seems to be a good choice, but would you pair it with the jwt flywheel? is the jwt flywheel significantly ligher than stock - ie, will the motor spin up/down more easily with this combo?
are there other combos that would be 'better'? this is for a 40% street, 60% track day car, soon to be aps single-turboed.
ahm
Old May 29, 2005 | 08:27 PM
xxlbeerZ's Avatar
xxlbeerZ
I think I'm going to go RPS, had two of them in the past and they worked great. I never saw that they made a 350z clutch, only 300zx.
Old May 29, 2005 | 08:44 PM
Z BOY's Avatar
Z BOY
here: http://www.jimwolftechnology.com/customer_part.asp
Old May 29, 2005 | 08:47 PM
zman1910's Avatar
zman1910
huh?
Old May 29, 2005 | 08:49 PM
Z BOY's Avatar
Z BOY
try the edited one. got sent to wrong page.
Old May 30, 2005 | 08:36 AM
barthelb's Avatar
barthelb
Master
Jwt Clutch and Flywheel work perfect. I wouldn't recommend anything else. No slippage, nothing justs clamps quick and no problems.
Old May 30, 2005 | 10:39 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
We sell all of them. Contact me with your intended power goals, and I will help you decide on what's best.
Old May 30, 2005 | 10:41 AM
cquence 350 [Z]
I will be contacting you real soon Sharif. Thanks!
Old May 31, 2005 | 12:44 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
what about just to replace stock cluch... is JWT okay with similar pedal feel?
Old Jun 4, 2005 | 04:34 PM
InjectedPerformance's Avatar
InjectedPerformance
Vendor - Former Vendor
I must say RPS Pressure plate and CYnRG flywheel is the way to go. Street disc holds 550 ft lb tq. Flywheel weighs 18lbs with segmented replaceable shields.
www.turboclutch.com
Old Jun 4, 2005 | 05:15 PM
g356gear's Avatar
g356gear
JWT has a replaceable surface for their flywhel as well.
