Boost and Tranny
Old May 31, 2005 | 08:16 AM
GMADD's Avatar
GMADD
Question Boost and Tranny
I'll be sending my ECU to TS for a reflash, setting at 8.5psi and installing the CAS wire once the ECU is back.
Now my question is can my auto tranny support this much power ?
Does anyone have this much boost on an 5AT car ?
Thanks !
Tasso-
Old May 31, 2005 | 08:20 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Thanks !
Tasso-
so, have you rebuilt your motor like your sig suggests?
and you plan on running 8.5 psi max?
Old May 31, 2005 | 08:38 AM
GMADD's Avatar
GMADD
well...not really
I just want to see how the tranny holds up to 8.5psi first and go from there.
the boost will always go up
Old May 31, 2005 | 09:35 AM
MOTOP's Avatar
MOTOP
Just as a precaution measure I recommend tranny cooler.
Old May 31, 2005 | 09:44 AM
GMADD's Avatar
GMADD
It's already installed.
Old May 31, 2005 | 10:39 AM
MOTOP's Avatar
MOTOP
Another problem that we had with our tranny was 6600rpm redline. Tranny didn't have enough time to upshift. TSed ecu seemed to have addressesd that issue, but then again, we installed flashed ecu along with full Level10 tranny.
Old May 31, 2005 | 10:45 AM
MOTOP's Avatar
MOTOP
In general there are quite a few unknowns with our trannies and FI.
We cranked the boost up to 13.5lbs and after about 400miles tranny stopped working properly.
P0744 A/T TCC S/V FNCTN, trying to find a remedy for that right now. Any help is apreciated.
Old May 31, 2005 | 10:46 AM
GMADD's Avatar
GMADD
How much power are you running with that tranny ?
I'll be getting the VB upgrade from Stillen and that's it. I hope I wont be ending up getting a new tranny.
Old May 31, 2005 | 10:51 AM
MOTOP's Avatar
MOTOP
We never had a chance to dyno the car with new tranny. At 0.8Bar car was dynoed 298kW ~ 410whp. Greddy TT and 8.5:1CR motor. That was on stock out of the box e-manage tune.
I think that now with TS Greddy tune and 0.92Bar we're somewhere in the 450-460whp range. Couple of days before the tranny died we pulled 5-6 carlengths on C5 vette with basic boltons.
Old May 31, 2005 | 11:05 AM
GMADD's Avatar
GMADD
The Level10 tranny gave out ? or stock ?
Old May 31, 2005 | 12:12 PM
MOTOP's Avatar
MOTOP
Level10
Old May 31, 2005 | 12:20 PM
GMADD's Avatar
GMADD
Level10
That must be a drag
So do you think I should be ok at 8.5psi ?
Old May 31, 2005 | 12:28 PM
PumpedVA's Avatar
PumpedVA
I am having 0 problems with my level 10 work. but i am only running 350whp 0nly thing I noticed was shift to 2nd is harder then any other gear
Old May 31, 2005 | 12:34 PM
MOTOP's Avatar
MOTOP
PumpedVA, did you get full tranny as well ?
Old May 31, 2005 | 01:09 PM
PumpedVA's Avatar
PumpedVA
No just the valve and tourqe work
Old May 31, 2005 | 05:22 PM
zzzya's Avatar
zzzya
What do you mean when you say full tranny? I have the Level Ten TC and VB upgrades and plan on a TT setup eventually.
Old May 31, 2005 | 05:32 PM
GMADD's Avatar
GMADD
I think he got the whole tranny rebuilt.
Old May 31, 2005 | 10:56 PM
MOTOP's Avatar
MOTOP
Correct, including upgraded frictions and steels.
Sam swore this tranny will hold 600whp daily.
Old Jun 1, 2005 | 03:14 PM
zzzya's Avatar
zzzya
He told me that with just the TC and VB that the tranny would be good for 600rwhp????
Old Jun 1, 2005 | 03:29 PM
MOTOP's Avatar
MOTOP
Whatever Sam says, make sure you have it in writing, so you have point of refference if push comes to shove.
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
