If you can guess the source of my oil leak....
You left the dipstick out.
Maybe I shouldn't be working on cars afterall?!
Originally Posted by ccartwright
We have a winner!! Yes I took it out Saturday when I was replacing the gasket on my LHS water pipe and plum forgot to put it back in. I figure I lost a good half quart of oil; it's all over my engine bay and garage floor....
Don't worry about it I knew the answer because that happened on my 300ZX at a shop, they called me to tell me they had my dipstick still there!
Originally Posted by westpak
Well where is my star?
Thanks beerz! We can always count on you to come through with the nifty graphics!
So after searching my garage for half an hour, I found it, now I'm going to take her for a long ride; hopefully leak free for once!
how about the smoking issue...did that get solved too?
And just a note...if you overfill your oil...it will come burping out the dip stick as well..and scare the crap out of you.
I trimmed some of the oil return line earlier tonight on the LHS turbo because it was damn near a straight horizontal line in the middle of the hose; now there is more of a downward drain. But I have not done anything about the RHS oil drain; will look at that tomorrow. I suspect I'll find the same thing. If that doesn't fix it, I'm taking it this weekend to have it tuned at SGP in Houston, so I'll have them look at it.
It still smokes some as the rpm's are coming down. I drove the car some, then got out and checked the exhaust as it was running: no smoke what so ever. Then I stuck my foot inside and revved it up to about 3 or 4 grand, ran back, and sure enough, a little bit of smoke coming out of both pipes.
Remember - The proper level is at add on stock dip-stick
Cheers Amy
Narcotic has a similar issue.. AC
Originally Posted by AmyCroft
Until APS sends a dip-stick
Cheers Amy
Cheers Amy
Like I have said earlier.... I would drain the oil and add exactly 6 quarts... I have had my kit on for almost 14k miles with no oil problems.... Good Luck and enjoy!!!
Originally Posted by one3502nv
OR-----
I started with exactly six quarts
