Turbonetics installation???
Old Jun 9, 2005 | 07:00 PM
xxlbeerZ's Avatar
xxlbeerZ
Originally Posted by Turbonetics
Oops!
Old Jun 9, 2005 | 09:35 PM
Ngoc413's Avatar
Ngoc413
Originally Posted by MIAPLAYA
BTW the turn around time for the flash is only 3 days from shipped to installed.
So who do i send the ECU to. to get it reflash? and is this reflash thing safe at all? what if they messed it up. I heard ecu is a very expensive thing to rteplace or fix. ohh yea and do they charge you when you send the ecu to them for the reflash?
Old Jun 9, 2005 | 09:46 PM
kcobean's Avatar
kcobean
The ECU is sent to Turbonetics in a provided FedEx shipping container. The reflash is safe, not sure what you mean by 'messed it up'. If they were to damage the ECU, they would replace it at no cost to you. The cost of the reflash and the shipping is included in the cost of the kit.
It sounds like you're interested in this kit and have lots of questions. I'd recommend you read up on some of the thread here in the F/I section of the forum. MIAPLAYA and a few others have made very comprehensive accounts of this kit both during install and on the road. Good luck.
Old Jun 9, 2005 | 10:44 PM
Speed Dreams's Avatar
Speed Dreams
Technosquare will build a custom program to your spec, you just need to communicate what you want them to built into the flash. If you want a custom tune you can feel confident since they developed the T-netics tune, direct custom tunes will cost 600.00.
Originally Posted by kcobean
That would probably require some back-n-forth with T-netics. I know the Speed Dreams guys in NM actually worked with TS to create a special tune to deal with the altitude. In theory though, the a/f should be dead on since all of the sensors are in place to allow the ECU to adjust as needed based on the maps.
Old Jun 10, 2005 | 06:48 AM
Phatmitzu's Avatar
Phatmitzu
Or keep the standard T-netics tune comes with the kit. Buy a emanage for ~$300 and spend a couple of hours on the dyno(~$150/hr). Costs about the same but still will have the ability to retune it later if you change your mods or decides to boost up a little.
Old Jun 10, 2005 | 04:12 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Turbonetics also offers a "tuner" kit, which comes with everyone except for the reflash, and fuel injectors. You can save a few bucks, and put an eManage system together for about $420 for tuning purposes.
If you like to tinker, then go eManage. If you want a safe out of the box experience, with minimal hassel, then stock with the full kit and reflash.
We have a special until the end of the month on the Turbonetics full kits. $4720 shipped to your door...FYI. [end of shameless plug]
Old Jun 10, 2005 | 07:27 PM
taurran's Avatar
taurran
ECU Reflash > Emanage
That is, unless you're building your motor and cranking up the boost.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
