aftermarket transmission?
Old Jun 9, 2005 | 03:38 PM
sentry65's Avatar
sentry65
the burninator
Default aftermarket transmission?
I know this is probably a dead end, but are there any aftermarket transmissions or anyone who does transmission work that can make each gear longer - especially the first 2 or 3?
lowering the final drive to the 3.3 I'm guessing only does so much. Is there a way to get a milder 1-3rd gear in the transmission?
Old Jun 10, 2005 | 10:55 AM
socalsean's Avatar
socalsean
I'd call around to various aftermarket high-end transmission shops first. It won't be cheap but someone out there may have a solution for you as far as different gear ratios go.
On a side note, and this is extreme, if the bell housing on the stock Z tranny is removable, an adapter COULD be made which would allow you to mount up any transmission you'd like. Of course a custom throw-out bearing and maybe even a pressure plate/clutch may be needed. All depends on how deep you want to go. Good luck!
sean
Old Jun 10, 2005 | 12:01 PM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
350EVO said in another thread that they could do it. PM BJ and see what he quotes you.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
SharX59
Sep 27, 2015 09:23 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
