More Turbonetics Info (Cat Version Info)
Old Nov 1, 2005 | 08:37 AM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Gary Evans
Emissions testing for this system need does need to be conducted. For any states such as Arizona using the IM 240 test it is more complicated and difficult to pass than just an idle test. During the IM 240 test, the subject test vehicle is driven on the dynamometer for a period of 240 seconds (4 minutes) at speeds varying between zero MPH and 57.6 MPH.
To be meaningful for these states actual IM 240 results are needed. Many people myself included cannot afford to install a system that cannot pass local emissions testing.
The whole point of doing emissions testing is to do exactly that. It is actually going to roll on the emissions dyno and make sure it passes all the required emissions levels for testing. So basically we are going to make sure the car will pass the sniffer under all conditions and then as long as your state does not have a visual insepction you are good to go. If you have visual inspection like Cali then you just need to find someone who will run the car on the sniffer and look the other way as to where the cats are...
Old Nov 1, 2005 | 11:29 AM
Gary Evans's Avatar
Gary Evans
Good plan!
Old Nov 1, 2005 | 11:47 AM
MIAPLAYA's Avatar
MIAPLAYA
Good plan!
Thank you...
Old Nov 20, 2005 | 07:39 AM
kopfjaeger's Avatar
kopfjaeger
Any update on this? I just poked around Turbonetics website a bit, but didn't see any data. Just curious .
Old Nov 20, 2005 | 08:25 AM
MIAPLAYA's Avatar
MIAPLAYA
Yeah sorry...Mossy Performance has a Turbonetics kit installed on their 05 Z and have the cat downpipe I gave them. I am just waiting for them to roll it on the emissions dyno to get some numbers...
Old Dec 13, 2005 | 01:06 PM
dovla's Avatar
dovla
+1 ?
Old Dec 13, 2005 | 04:09 PM
MIAPLAYA's Avatar
MIAPLAYA
Sorry fellas but Mossy's Z had an extended stay for some some testing. They are getting it back Friday. I know its been a while but I will push Greg over at Mossy for some numbers next week. I'm doing what I can I promise
Old Jan 16, 2006 | 07:43 AM
dovla's Avatar
dovla
Perhaps I missed the post in some other thread? If not, please post the numbers, good or bad. Thanks
Old May 3, 2006 | 12:39 PM
LODOSS's Avatar
LODOSS
Stock 350z with TN cat kit, 330 at wheel.. should it make that much of a difference?
Old May 3, 2006 | 01:00 PM
Alberto's Avatar
Alberto
Cranky FI Owner
6MT, 5AT? How much boost? What type of dyno? What is the A/F like? Not enough info for us to provide an opinion...
jlimquest's Avatar
jlimquest
I have the TN w/ CAT for the 5AT (356 whp & 335 tq = Mustang Dyno). Here's my post:
https://my350z.com/forum/forced-induction/174014-turbonetics-at-w-cat-by-danzio-worth-the-wait.html
Old May 3, 2006 | 01:05 PM
Alberto's Avatar
Alberto
Cranky FI Owner
^^Thats right on considering the slightly higher drivetrain loss and the dyno type.
Old May 3, 2006 | 03:00 PM
Nismo 350z's Avatar
Nismo 350z
Hey Miaplaya, how can you pass visual with this kit. I mean yeah it can pass the sniffer, but I don't understand how all of you FI guys do it. Especially here in so. ca. Also I heard that if you have a front mount visible, the po-po will pull you over. I know you can paint the IC black but the turbo is so obvious when you pop the hood.
Old May 3, 2006 | 03:54 PM
g35pm's Avatar
g35pm
You can't pass visual in cali with this kit. That's why my car is as stealth as possible.
Old May 3, 2006 | 05:15 PM
MIAPLAYA's Avatar
MIAPLAYA
Theres certain shops that look the other way. And as long as you don't have the front mount wide open in front of the car your chances of getting pulled over are only as high how stupid you drive..
Old May 3, 2006 | 05:24 PM
jlimquest's Avatar
jlimquest
Yup...that's why I installed my front plate & took off the "turbo" emblem I had at the back. It needs to be as stealth as possible & as Mia indicated just "driving smart".
Old May 3, 2006 | 05:58 PM
Alberto's Avatar
Alberto
Cranky FI Owner
If I wanted stealth Id run a grill that covered the FMIC besides the factory or paint the IC black....
Old May 4, 2006 | 12:11 AM
  #38
wilric44's Avatar
wilric44
Mia or anyone, I just installed RT CATs and stillen exhaust, it seems if i wanted to add the turbonectics kits i would loose half of what I installed.
Old May 4, 2006 | 05:48 AM
  #39
MIAPLAYA's Avatar
MIAPLAYA
You would lose the RT cats yes but you could fab a reverse y pipe for the Stillen exhaust...
Old May 4, 2006 | 05:57 AM
  #40
Gary King's Avatar
Gary King
So did the cat version pass the sniffer?
