What boost control are being used?
Old Jan 25, 2007 | 06:49 PM
QuadCam's Avatar
QuadCam
Originally Posted by MRC Motorsports
That is becasue the Z does not have an speed control output on the ECU.The 4 speed sensors of the car are routed to the BCM and in return routed via a CAN bus line to the ECU. We were goint to try and getting a signal off of one of the speed sensors on the front wheel.
Julian, what about the speed sensor for the NAV system. I know, I know, not many Zs have NAV, but it is something to think about.
Old Jan 25, 2007 | 06:58 PM
QuadCam's Avatar
QuadCam
Originally Posted by USN HM 350Z
I use the Hallman Evolution Rx Manual Boost Controller. Works flawlessly and comes with a cockpit control.
http://www.hallmanboostcontroller.com/applic.html
I have the hallman Pro RX....it is great. I only wanted to up the boost a couple of PSI, and the hallman is perfect for it. They send a regular and a light spring. The light spring is used where you are only looking at upping the boost a few pounds. Plus, I also went with the lightweight ceramic ball insert, too.
Old Jan 26, 2007 | 04:49 AM
Nowell's Avatar
Nowell
National Z Club
Not a bad idea, ill talk to Dave about it today and see what he thinks also. Would love to get this function working though.
Old Jan 26, 2007 | 06:19 AM
Julian@MRC's Avatar
Julian@MRC
Dont think it will work.The boost controler most likely needs an analog signal, like right off the sensor itself, before it goes to the BCM. Most likely the speed from all 4 wheels is sent to the BCM and the Traction control Computer, then the speed and traction is calculated and sent to the other units like the ECM and NAV via the CAN bus line. I think you would need to get the signal right off one of the sensors.
Old Jan 26, 2007 | 07:33 AM
Ozzie@Hppracing's Avatar
Ozzie@Hppracing
wow, those are pretty expensive
I don't think it was that bad. I beleive it was like 400 or so.
Old Jan 27, 2007 | 12:19 PM
al v's Avatar
al v
Take a look on this thread :
https://my350z.com/forum/forced-induction/156023-i-got-the-two-step-working-on-the-emanage-ultimate.html
I´m using this wire with my Apexi AVC-R , and it works perfect..........
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
