eManage Ulimate--Almost here..and MUCH IMPROVED!
Old Aug 18, 2005 | 09:59 AM
  #401
IceY2K1Max's Avatar
IceY2K1Max
So you have tried it on a/another car unsuccessfully?
Originally Posted by Sharif@Forged
Dandy, the EU has no way of adding fuel to a non-signal that the EU gets. It is still dependent on the stock signal, and if the ECU cuts fuel for one cylinder for one combustion event, the EU has no way of adding to a zero signal.
Hope that makes sense. If someone has gotten it to work, I would like to talk to them. THE VQ ECU is very different from most.
Old Aug 18, 2005 | 11:40 AM
  #402
Jason kiDD's Avatar
Jason kiDD
Its funny because with my 05 I have yet to experience said rev limit. I can take the car all the way to redline with VCD off and have no problems in every gear..
Old Aug 18, 2005 | 11:44 AM
  #403
IceY2K1Max's Avatar
IceY2K1Max
Nissan tachs are notoriously lazy, so you just aren't going high enough.
My car has a 6400rpm limiter, confirmed via OBD logging, but when it kicks in, the tach is at 6800-6900rpm depending on gear.
Old Aug 18, 2005 | 11:47 AM
  #404
DandyMax's Avatar
DandyMax
Yes but isn't that what the hold time is supposed to do? Get past that short time of zero signal(s)?
Perhaps I misinterpreted its capabilities. If that's the case, then it's not good news for us VQ'ers.
As Ice asked, have you tried to advance the rev limit on a VQ engine? Even if it didn't work I'd really like to know if anyone has actually tried it.
Old Aug 18, 2005 | 11:56 AM
  #405
Jason kiDD's Avatar
Jason kiDD
If I take it any higher I will be past redline..
Old Aug 18, 2005 | 12:02 PM
  #406
IceY2K1Max's Avatar
IceY2K1Max
Japanese are color blind...your tach "redline" is nowhere near the actual rev-limit or at least on my car, ie off by 300-400rpm maybe.
BTW, just kidding on the color blind comment.
Old Aug 18, 2005 | 01:23 PM
  #407
mattymax's Avatar
mattymax
Well it may look like us VQ guys are shi* outa luck for raising the rev limit. It would be good to see someone actually try it and see what happens...and report back here
-matt
Old Aug 22, 2005 | 07:05 PM
  #408
sentry65's Avatar
sentry65
the burninator
still waiting on the news with the emanage ultimate and the NA car, sorry if i'm being annoying
Old Aug 22, 2005 | 07:49 PM
  #409
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The sessions was rescheduled, but it WILL happen tomorrow (Tues).
Old Aug 23, 2005 | 06:29 PM
  #410
350zWarz's Avatar
350zWarz
any good results?
Old Aug 24, 2005 | 04:24 AM
  #411
G I Love My Car's Avatar
G I Love My Car
I will give a full write-up soon, I am just to busy to sit in front of the computer this morning. But the final results where 10.1hp and a damn near perfect 12AF reading. There car has power where it was lacking before, I also had a couple of dips which eric and sharif ironed after playing for awhile. But yes my final HP number is 271.9whp. I will post dyno sheets later, but once again Thank You to Eric and Sharif as always there customer service far exceeds any I have delt with in this buisness. There know how about the VQ motor is awesome.
Old Aug 24, 2005 | 06:32 AM
  #412
Sharif@Forged
Forged Performance
Glad you were happy with the results..can't wait to see those dyno posts.
Old Aug 24, 2005 | 09:44 AM
  #413
CpraceZ's Avatar
CpraceZ
Glad to hear your happy with your car, let us know if you need anything else like some boost lol
Old Aug 24, 2005 | 09:55 AM
  #414
sentry65's Avatar
sentry65
the burninator
cool, not a bad power gain considering your car doesn't have cams or headers
the nice thing is the perfect A/F and that it and your timing won't be changing all the time
Old Aug 24, 2005 | 04:39 PM
  #415
350zWarz's Avatar
350zWarz
looks like a nice gain, +1 on dyno charts
Old Aug 31, 2005 | 07:36 AM
  #416
spdkils's Avatar
spdkils
I started sorting out the wires lastnight after work.
Do we know if it can read the speed wire that the CAM signal outputs? (I believe that is correct anyway... I don't have the service manual right in front of me I'm in training all week.)
Everything seems pretty straight forward...
I'm not sure I would trust myself to turn the car over with the greddy in... But maybe if I can get a base map, then take it to the dyno again. =D
Old Aug 31, 2005 | 08:14 AM
  #417
Badmonkey's Avatar
Badmonkey
I tried tracing the speed sensor signal, and it is a pain. There is a thread about it in another emanage ultimate thread. I traced it going into the gauge cluster, I think it will work from there, but have yet to try. I have too many other things on the plate right now.
Old Sep 1, 2005 | 09:20 AM
  #418
Z33Concept's Avatar
Z33Concept
SO IS THE ULTIMATE EMANAGE BETTER than The Uni-Chip correct?
Old Sep 1, 2005 | 10:02 AM
  #419
Sharif@Forged
Forged Performance
I guess it depends on your defination of better. The EU has several high end features, that Unichip lacks, but the Unichip is also a very capable tuning device. They tune the cars in slightly different ways.
On high boost cars, when the limits of the MAF are reached, the EU is going to be a better option...especially if you plan to run much larger injectors.
Old Sep 1, 2005 | 11:10 AM
  #420
spdkils's Avatar
spdkils
I've read thru the EU manual a few times now, looked over settings etc.
If I were to install the EU "WITH" the UniCHIP could I use the data logger to gather all the information needed to replace the uniCHIP with the EU @ the ~same~ settings?
(Read timing, read I/J Duty cycles, etc.)
Then just make a map to replace the uniCHIP.
(Since the Unichip actualy has LESS load points... And less overall features... I think it is substandard to the EU. However tuning on a load based dyno using the little injector/timing ***** would be VERY cool.)
spdkils
