eManage Ulimate--Almost here..and MUCH IMPROVED!
Sharif,
Let me know if you think I should pick up anything else with this.
1) sharif@forged
2) zzzya
3) 350zDCalb
4) g356gear /w autosport harness,ultimate harness+pressure sensor/harness
5) 002-M-P
6) johanna1
7) cquence 350 [Z]
8) KShep
9) derek_i
10) Badmonkey_1
11) G35 6MT
12) cersoft
13) Hydrazine /w autosport harness,ultimate harness
14) Rayden2001
15) sentry65
16) lucidazn /w autosport harness
17) Machupo
1) sharif@forged
2) zzzya
3) 350zDCalb
5) 002-M-P
6) johanna1
7) cquence 350 [Z]
8) KShep
9) derek_i
10) Badmonkey_1
11) G35 6MT
12) cersoft
14) Rayden2001
15) sentry65
17) Machupo
1) sharif@forged
2) zzzya
3) 350zDCalb
5) 002-M-P
6) johanna1
7) cquence 350 [Z]
8) KShep
9) derek_i
10) Badmonkey_1
11) G35 6MT
12) cersoft
13) Hydrazine
14)Rayden2001
15)sentry65
16)lucidazn /w autosport harness, ultimate harness+pressure sensor/harness
2) zzzya
3) 350zDCalb
5) 002-M-P
6) johanna1
7) cquence 350 [Z]
8) KShep
9) derek_i
10) Badmonkey_1
11) G35 6MT
12) cersoft
13) Hydrazine
14)Rayden2001
15)sentry65
You mean ignition advance? The blue didn't have a rev-limit change map as far as I've seen(ie internet). The GOLD version had one, but I don't know anyone that's converted a blue-to-gold on a VQ.
Also, from the trouble I've heard from others trying to connect AEMs EMS and Perfect Powers SMT6s with Nissan crank/cam position sensors, I'm doubtful but hopeful the ignition advance features can work on VQs.
When you called Greddy, what did you ask them specifically? I know it's going to be universal like the blue so some features will work, however I'm wondering why it's not listed in the application list here: http://www.geocities.jp/bigsinglewor....htm#emunissan
Anyways, I don't want to waste your time, just anxious with a zillion questions.
Make sure you post up the manuals ASAP, if digital, so we can see more into the capabilites of this bad boy.
Thanks,
Alex
Thanks,
Alex
Originally Posted by Sharif@Forged
Rev limit increase is the only thing that likely wont work. It doesnt work on the blue eManage, and unless there is some new feature change, I dont think it will work on our ECU with the Ulitimate.
I'll check it out thought, for sure.
Forged Performance
Forged Performance
Sharif, and if you haven't bought any other harnesses for the blue emanage (that is included in the GReddy TT kit), what do you need if you are switching to the ultimate emanage?
Is there an on/off provision or capability with the piggyback for nitrous applications? Seems like an ideal tool for a dry system if it can be turned on or off or even change programs with system activation? Thanks
I asked Greddy if the EU was compatible with the 350z, and they confirmed it for me. I am going to make this a risk free proposition for everyone involved, as I will personally complete the install, testing, and tuning, and can clearly articulate the features that work on the 350Z, and those that don't.
I am not promising you that every single feature will work on the VQ motor, but even things like add/reduce IPW, and individual cylinder trim are pretty worth while....along with A/F target tuning. There is no reason these particular features wouldnt work on the VQ motor. Timing advance is questionable, but I hope it works. Since 95% of the time, we are trying to retard timing, its not a huge issue if the EU can't advance on our motors.
Thanks for the questions and feedback.
Timing advance would be really nice for us NA guys though so hopefully it works or this may not be as good of a solution without both a TS reflash for timing and the Emanage for fuel.
Forged Performance
Forged Performance
Sharif,
Just a note. I'm getting this on the condition that it can advance timing on the VQ. Its the #1 feature I'm looking for.
1) sharif@forged
2) zzzya
3) 350zDCalb
5) 002-M-P
6) johanna1
7) cquence 350 [Z]
8) KShep
9) derek_i
10) Badmonkey_1
11) G35 6MT /with autosport harness & ultimate harness
12) cersoft
13) Hydrazine /with autosport harness & ultimate harness
14) Rayden2001
15) sentry65
16) lucidazn /w autosport harness, ultimate harness + pressure sensor/harness
1) sharif@forged
2) zzzya
3) 350zDCalb
5) 002-M-P
6) johanna1
7) cquence 350 [Z]
8) KShep
9) derek_i
10) Badmonkey_1
12) cersoft
14) Rayden2001
15) sentry65
Originally Posted by nis350ztt
Any datalogging features on this?
I ended up buying the Innovate Motorsports LM-1 and LM-3 data logger kit, from Sharif, just for that purpose. Hopefully the 2 together can provide all the data logging and tuning control needed.
Forged Performance
Forged Performance
Sharif,
My hope, for instance, is that the eManage Ultimate can actually determine actual timing...and then plot it out across a map, as an example.
Thanks for the responses Tony and Sharif.
What datalogger would you recommend Sharif? I did some searching and found the Zeitronix, TurboXS DTEC (not really what I want though, don't you have to have a nintendo gameboy advance?), and Innovate Motorsports LM-1 and LMA3. So which out of those? The Zeitronix sounds nice, can datalog 9 hours straight, datalogs rpm, throttle position, a/f, egt, and boost. (plus the small LCD display)
The Zeitronix sounds nice, can datalog 9 hours straight, datalogs rpm, throttle position, a/f, and boost.
Zeitronix can also do EGT's . Thier sensors seem very accurate . That PLX R-500 Does look really nice
I see that the Innovate Motorsports LM1 + LMA3 can be used with the engine management, can the others? I did some comparing and the PLX R-500 seems like the best, from what all you can datalog, though I didn't see it list if you could use it with engine management.
Forged Performance
Forged Performance
The software and mapping is unbelieably robust, and the Aux box has quite a few internals sensor, including a MAP sensor, EGT, etc....
Here is the link: http://www.innovatemotorsports.com/x...cat=250&page=1
The LM-1 plus AUX box retail for $599, and the selling price si $560 shipped. Nobody ever discounts Innovate products, but we still offer a small discount, and free shipping.
