wanting to go up to 7 - 7.5 psi with my Greddy kit, double check me!!!
Old Jul 7, 2005 | 02:53 PM
mazx6's Avatar
mazx6
Originally Posted by nis350ztt
I'm pretty sure Todd missed the TS reflash you said you were getting. That's all you need (other than a boost controller and you have that).
ccartwright, pretty sure it doesn't, you should mention that to Technosquare mazx6, it will need a different AFR and probably slightly different ignition timing.
tell that i don't have cats, or tell them i scared to drive the car..
Old Jul 7, 2005 | 04:23 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by ccartwright
I thought that the reflash was safe as is without pulling any more timing? Aren't there a few guys who don't even use the emanage, just use soley the reflash?
doh!!! you are totally correct... i wasn't thinking when i posted that...the reflash can adjust for a timing retard solution...making the e-manage timing retard unecessary..personally, i like to still have the ability to control things like that with the piggyback (wish i had a standalone though)
Old Jul 8, 2005 | 04:03 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Looks like you are all set to go.
I will make one suggestion, and that is immediately after the reflashed ECU is installed, please head straight to a dyno, and check your A/F across the various RPM ranges and load points. Ever car is different, and IMHO, you have to double check all reflashes.
Old Jul 9, 2005 | 06:36 AM
theking's Avatar
theking
I still don't know why people don't get an in car WBo2 in their cars. All this money, what's $350 more. Plus if you have the emanage their are programs out to datalog the o2 into it. A little road tuning, logging and adjustments and you're close to done.
Old Jul 9, 2005 | 07:43 AM
Sharif@Forged
Forged Performance
^^^I would agree with this, and the vast majority of my F/I customers elect to run a wideband O2 gauge^^^ But each person has a budget and goal in mind, and sometimes, especially when keeping the setup relateively simple, and low boost, they feel the wideband is not as necessary.
Old Jul 9, 2005 | 08:13 AM
mazx6's Avatar
mazx6
good idea. thanks sharif.
Workshop12
Mar 23, 2020 01:45 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
