Will an ATI work on an '05?
Old Jul 13, 2005 | 10:27 AM
chrisle7220's Avatar
chrisle7220
Default Will an ATI work on an '05?
I was just wondering if i could use a procharger kit on an '05 enthusiast? I havent seen too many forced induction 05's and didnt know if it was going to work. I called a few places that sell the procharger and they said it will work, but i called procharger directly and some lady answered saying it would not work. Has anyone done it yet or know of anyone doing it? Please let me know asap cause i may be buying the kit very very soon.
Old Jul 13, 2005 | 07:40 PM
chrisle7220
anyone?
Old Jul 13, 2005 | 07:47 PM
zand02max's Avatar
zand02max
I don't see why not, its the same engine as the 03/04's.
Old Jul 13, 2005 | 08:34 PM
chrisle7220
I heard the ecu's were a little different?
Old Jul 14, 2005 | 02:23 PM
silverevo68's Avatar
silverevo68
I talked to the lady at ATI Prochargers and she said that they have tested the 05 350z in house and it does work with the new electronics that come with the 05 350z kit
Old Jul 14, 2005 | 04:35 PM
chrisle7220
O, so buying a used kit wouldnt work on an '05? The kit im buying came off an '03 model. I just dont see whats different, what fuel management are they going to use on the '05 kits? I would think it would still be the aeromotive dfmu, and if thats the case, they procharger kits should work no matter what year they were produced.
Old Jul 15, 2005 | 06:05 AM
silverevo68
Yes, a used kit will work but you need to run the New eManage Ultimate that should work on the 05 350z and 440 injectors and a walbro fuel pump and the J&S Safegaurd to pull timing, that fuel solution is good to about 420whp but above that I would run a return fuel system
Old Jul 15, 2005 | 10:12 AM
chrisle7220
Why wouldnt i be able to run the aeromotive dfmu?
Old Jul 15, 2005 | 07:56 PM
silverevo68
You can use the aeromotive dfmu but you will need to get the electronics that come with the ATI Procharger kit for the 05 350z
Old Jul 18, 2005 | 10:19 AM
overZealous1's Avatar
overZealous1
i had a kit on my 03 and there really is no spot where it wires into the ecu at all. or any other part of the car. the dfmu is really a stand alone with no reference from the car other than boost. i see no reason it would not work. but a good idea to have some way to pull some timing if going over stock ati boost.
Old Jul 18, 2005 | 12:28 PM
mojo powered's Avatar
mojo powered
the E-manage Ultimate would be all you need as far as tuning electronics go.. you don't need J&S to pull timing, the EU will do that. I would also ditch the fmu and get injectors, fuel pump and return fuel system to get the most out of the kit safely.
hulkout
Tuning
Sep 30, 2015 12:33 PM
