Need Help Asap Turbonetics????
Old Jul 21, 2005 | 12:24 PM
vaderzo6's Avatar
vaderzo6
Default Need Help Asap Turbonetics????
ok installed the kit everything is good in terms of leaks and such, but the car runs like complete ***(idle sucks *****) revs ok. blow off valve seems not to be opening? any problems like this and what are the fixes. anybody have any insight?
Old Jul 21, 2005 | 12:26 PM
Peking's Avatar
Peking
Well sir from what you just posted for us to read... That ain't going to help us any...
Best thing to do is go over again your Turbo instructions, your BOV instructions, and your Wastegate instructions... That is what I did, and doubled checked the work to find out how to solve my problems along with posting up here with the more specific info
Old Jul 21, 2005 | 12:31 PM
vaderzo6's Avatar
vaderzo6
idle sucks ***** and will not hold an idle i havent driven the car yet just started it up and it wont hold an idle what possible problems could this be related too. it seems to rev fine. nothing leaks(air or fluid alike).
Old Jul 21, 2005 | 12:40 PM
MIAPLAYA's Avatar
MIAPLAYA
Did you modify the fuel pressure regualtor in the intank pump assy. What is your fuel pressure right now?
Old Jul 21, 2005 | 12:53 PM
vaderzo6's Avatar
vaderzo6
i think i found the problem, a very small hole on the turbo silicon coupler. hopefull when i put a new one on it will fix the problem
Old Jul 21, 2005 | 12:55 PM
MIAPLAYA's Avatar
MIAPLAYA
Did you modify the fuel pressure regulator in the pump assy? The silicone coupler should only cause a boost leak. Not rough idle...
Old Jul 21, 2005 | 01:42 PM
Peking's Avatar
Peking
As you know Rob, my fuel pump was not modified as directed by the new instructions for the kit (since my kit came with the first gen instructions)... And my idle is not showing any kinds of problems infact it is better than before LOL...
Could it be possibly incorrect injector install/spark plug gapping/damage and/or incorrect fuel pump modifing/install?
Old Jul 21, 2005 | 01:46 PM
MIAPLAYA's Avatar
MIAPLAYA
Absolutely....this is just the first thing I check for...
Old Jul 21, 2005 | 01:57 PM
narkotic's Avatar
narkotic
Poor idle during initial startup after major modifications such as this is caused by removing the throttle body, or having the battery disconnected after a while. I had this problem after doing my APS TT install for a whilie and it sucked. You have to either drive it a bit for it to relearn the drive by wire settings or perform a manual learn as in the service manual. If that still gives you idle problems after doing so (drive w/ the AC on to keep the idle up), try to tighten the BOV. I put a Greddy RS BOV on my APS TT kit and it was too loose causing the car to just die, I tightened it up and walla never dies anymore..
good luck
Old Jul 21, 2005 | 03:29 PM
vaderzo6's Avatar
vaderzo6
ok well it wasnt that. but my bov is either too loose and open or its the self learning thing ill let you guys know soon
Old Jul 21, 2005 | 03:30 PM
Peking's Avatar
Peking
good luck
Well something like that happened to me, and I actually called MIAPLAYA cause after we started my car a light came on and for some funny reason I cannot remember which one but it was on. We scan'd it and it was the throttle learning thingy, we cleared the code then we started it up again... It was fine.
Oh wait, it was the MAINTANCE REQ. light... And even with this my idle was not ruff.
Old Jul 21, 2005 | 03:50 PM
vaderzo6's Avatar
vaderzo6
bov not opening or move...is there a rubber spacer on the inside of the intake manifold that i missed? idle still messed up
Old Jul 21, 2005 | 03:58 PM
MIAPLAYA's Avatar
MIAPLAYA
DID YOU MODIFY THE FUEL PRESSURE REGULATOR IN THE INTAKE PUMP?
Old Jul 21, 2005 | 04:02 PM
Peking's Avatar
Peking
Frankly this guy is starting to scare me alittle with his posting
I am starting to feel maybe this fellow was not correctly prepared to do such a install.
Old Jul 21, 2005 | 04:03 PM
MIAPLAYA's Avatar
MIAPLAYA
Did you attach the boost signal line to the top port. Under what conditions is the BOV not opening. Are you achieving full boost?
Old Jul 21, 2005 | 04:28 PM
vaderzo6's Avatar
vaderzo6
YES I MODIFIED THE FPR BY DRILLING THE OPENING SLIGHTLY LARGER. im goin to through it all together and take it out and see what happens.
Old Jul 21, 2005 | 04:44 PM
Peking's Avatar
Peking
Good luck man.
Old Jul 21, 2005 | 04:53 PM
MIAPLAYA's Avatar
MIAPLAYA
What is your fuel pressure? What is your vaccum reading on your boost gauge. You should have a boost signal line going from the plnum to the BOV (upper port) and a line going from the compressor discharge to the lower wastegate port. If its not a fuel issue then it is a vacuum leak or throttle relearn issue.
etkms
Jun 19, 2022 06:30 PM
LunchBox20
Oct 20, 2015 10:22 PM
