Who has 600+ rwhp and how did you get there?
Old Aug 11, 2005 | 05:21 AM
Yancy's Avatar
Yancy
Default Who has 600+ rwhp and how did you get there?
Right now, I'm running the Greddy TT Kit at 8 psi, walbro pump, technosquare ecu, emanage to scale, test pipes, Greddy Evo II, and CM stage IV clutch and lightweight flywheel. Numbers on a dynopak are 450 rwhp and 409 rwtq. I've done my fair share of surprising a lot of cars with my Z.
A guy a hang out with has a built forged V8 SC Saleen that use to make around 475 rwhp with the stock SC at around 13 psi (Saleens are 2 valve motors - atleast his is anyway). I was 20 for 20 or so against him from all kinds of various starting positions, until he just added a 75 shot of n2o. In a short race less than a 1/4 mile he took me by about 2 cars on bottle. I can't have this so something needs to get done. By the way, he just ran an 11.56 on bottle yesterday.
To get back to the point, I'd like to hear from those of you that are close to or over the 600 rwhp mark. I know the engine must be forged built, and you'll likely need 650cc injectors or larger and upgraded 1/2 axles from Sharrif or the driveshaft shop, but what I'm not sure of is if porting and polishing of the heads and intake is needed, along with a cam to get over the 600 rwhp mark? Also, wouldn't a 9.0:1 or say 9.3:1 piston give you a better chance to see this number and build boost a little quicker compared to a 8.0:1 or 8.5:1 piston? Thanks guys.
Old Aug 11, 2005 | 06:49 AM
mojo powered's Avatar
mojo powered
Sharif will chime in here in a little bit I'm sure but from what it seems like, you will need at least cams to get above 530whp or so.. that's my understanding.
Old Aug 11, 2005 | 06:59 AM
tinman's Avatar
tinman
this is the only one that i've seen so far
http://store.yahoo.com/sgpracing-store/ab03ni35.html
Old Aug 11, 2005 | 08:23 AM
GXCLUSIV's Avatar
GXCLUSIV
Gymrats G35 TT
Steve,
Soon as your G is ready for dyno, no doubt you'll be in that 600rwhp club.
Old Aug 11, 2005 | 08:33 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
umm, i 'm running 550cc injectors..but very high duty cycle...650's may be your best bet if u want to sustain 600+wrhp
i am in cali right now..running 16psi on approx 97 octane (mixing 100 and 91)
my setup is in the "cardomain" link in my sig
you don't NEED headwork or cams to reach 600...it just makes it much easier at less boost..much more efficient as well...
TODD
Old Aug 11, 2005 | 09:33 AM
mikeyj217's Avatar
mikeyj217
check out www.theexperience.com
Old Aug 11, 2005 | 09:35 AM
mikeyj217's Avatar
mikeyj217
by the way its a 6 second Z!
Old Aug 11, 2005 | 11:26 AM
tinman's Avatar
tinman
i thought this is for street set up VQ35
btw,did you ever break 600 mark yet Todd?
Old Aug 11, 2005 | 11:34 AM
Yancy's Avatar
Yancy
Thanks for all the responses so far guys. Yes, I'm looking for street set ups only.
Old Aug 11, 2005 | 01:32 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
well on the last forged motor, ran 603rwhp, 583tq (sae corrected)..so prolly around 540actual...which is plenty!!!
Old Aug 11, 2005 | 04:57 PM
tinman's Avatar
tinman
shest..anything over 400 IS plenty
Old Aug 11, 2005 | 05:08 PM
dharp65's Avatar
dharp65
Yancy, who did the work on your car?
Old Aug 11, 2005 | 07:01 PM
Yancy's Avatar
Yancy
dharp65,
A shop in Novi, MI does the work on my car. It's called Godspeed. Novi is a suburb of Detroit, which is not too far for me. The owner of Godspeed, Dan, is probably the best tuner in this area when it comes to Z's, STI's and EVO's. The shop is currently on Heslip Road off of 9 mile road, but they are moving into a larger facility in the near future.
Old Aug 11, 2005 | 07:04 PM
mchapman's Avatar
mchapman
APS have their TT 350z up to 734whp!!
So hopefully they will be selling parts required to get there soon.
Old Aug 11, 2005 | 11:21 PM
thawk408's Avatar
thawk408
I hope that is not on a stock motor?
Old Aug 12, 2005 | 04:59 AM
tinman's Avatar
tinman
link please.thanks
Old Aug 12, 2005 | 05:23 AM
Yancy's Avatar
Yancy
Wow, that's crazy. Can you post a link? It would be interesting to see what it takes to get that power. I'm guessing, sleeves, forged pistons and rods, ported and polished heads and intake, cams, oversized valves and springs, head and main stud kit, return fuel system with possibly dual pumps, and about 25 psi or possibly even some n20?
Old Aug 13, 2005 | 02:47 AM
mchapman's Avatar
mchapman
link please.thanks
No its not a stock motor and they arent using NO2.
Peter just mentioned it on **********, Im sure he'll do a proper update when hes ready. It will be very interesting to find out how they went about it!
Remove the space after tech when going to the link.
http://www.********** .com/forums/ind...showtopic=9851
Its making so much torque the ATS twin plate clutch cant hold so they are upgrading to the triple plate unit!
Old Aug 13, 2005 | 10:16 AM
BrianLG35C's Avatar
BrianLG35C
dharp65,
Great, I'll keep Godspeed in mind if I have any problems with my APS TT G35.
Old Dec 11, 2005 | 04:58 PM
JisNis's Avatar
JisNis
Peter just mentioned it on *********, Im sure he'll do a proper update when hes ready. It will be very interesting to find out how they went about it!
http://www.********* .com/forums/index.php?showtopic=9851
Anyone have the link still?
