TurboXS Announces the Z UTEC Release
Old Oct 13, 2005 | 07:11 PM
  #161
35ounces's Avatar
35ounces
03 CS Track 6MT
also, since the basic UTEC doesnt include the wideband feedback, knock feedback, and the pressure sensor for FI , what do those cost?
I need to know what I would need to order. I do not want to buy the UTEC and find that I didnt buy everything I needed when I go to install it.
Old Oct 13, 2005 | 07:23 PM
  #162
ThetunerFestNJ's Avatar
ThetunerFestNJ
Good questions.
Jermain, can you post all this information for people to make a better informed purchase..I so want one of these!!
Old Oct 13, 2005 | 10:43 PM
  #163
accordfreak's Avatar
accordfreak
If I can use a map sensor.. like a 3 bar map sensor, can I eliminate the MAF sensor all together? i'm new to vehicles with MAF's. thanks
Old Oct 14, 2005 | 07:56 AM
  #164
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
OK - I'll make it easy so everyone can understand
350Ounces - active knock correction is a standard feature of the UTEC - there is nothing else needed to buy and nothing to wire in. You can set the sensitivity via the utec itself, or just leave it as it comes from TXS and it will detec knock on the same sensitivity as the stock ecu does, and retard as much in the event of an knock event as much as the stock ecu does.
As far as datalogging with a wideband, in order to do so, you must purchase a Tuner or Tuner Pro. The UTEC will not integrate with any other wideband on the market aside from the Tuner or Tuner Pro. You can read all about the differences between the Tuner and Tuner Pro on any number of websites, including Turbo XS's. If you do not buy a Tuner, the UTEC still can datalog a host of parameters from timing to knock to boost to TPS - all configurable inside the UTEC "software". However, if you want to datalog wideband 02 as part of the mix, a Tuner or Tuner Pro is required.
If your car is FI, you would need to purchase the MAP sensor as well ($119.00 with the wiring harness that enables it to plug into the UTEC). This is a proprietary Turbo XS 5 (five) bar sensor. The stock MAF will still be retained for crusing, idle, and similar no boost driving scenarios. The MAP sensor is there for situations where boost is present - again, ensuring smooth idling, smooth driveability, without all the hiccups pure MAP based tuning can cause for novices and experts alike
Old Oct 14, 2005 | 08:20 AM
  #165
35ounces's Avatar
35ounces
03 CS Track 6MT
too many UTEC threads going! I posted on motoring: http://www.350zmotoring.com/forums/s...405#post445405
the local tuner god prefers eManage.
Old Oct 15, 2005 | 12:45 PM
  #166
ThetunerFestNJ
Jermain
Any updates??
Old Oct 15, 2005 | 08:27 PM
  #167
aalzuhair's Avatar
aalzuhair
Thanks Jermaine
To answer your question, I was just checking to see if I would have the ability to increase idle speed should I need to.
One last question if I may, with the UTEC installed, which ecu (stock ECU or UTEC) will control valve timing?
Thanks,
Az
Old Oct 16, 2005 | 11:01 AM
  #168
BlackTuner's Avatar
BlackTuner
Originally Posted by aalzuhair
Thanks Jermaine
Thanks,
Az
Az,
The UTEC will have the ability to control VTC. Initial release version will not but it is a software that we are definitely implementing.
Thanks,
Jermaine@turboxs.com
Old Oct 16, 2005 | 06:27 PM
  #169
aalzuhair's Avatar
aalzuhair
Jermaine, when do you think you will release a software version that would include all of these things.
Thanks,
Az
Old Oct 17, 2005 | 06:38 AM
  #170
BlackTuner's Avatar
BlackTuner
Thanks,
Az
Az,
Our engineers are busting their hump to get me software immediately. I will probably have an update later on this week.
Thanks,
Jermaine~
P.S. I will be tuninig the MRC beast again this week with stiffer w/g spring
Old Oct 17, 2005 | 06:48 AM
  #171
NoObTuNeR's Avatar
NoObTuNeR
What base maps will be downloadable at the time of release? Say we wanted a base map for just intake or exhaust mods. Or maybe if we got the aps tt tuner kit, will there be a base map we can use till we can get a proper tune? How far are you guys from the glen burnie area?
Brian
Old Oct 17, 2005 | 07:07 AM
  #172
damen's Avatar
damen
hey jermaine do you think you'd be able to tune my single turbo G35 coupe? if so just let me know when i can drop it off since your local to me. hehehehe
Old Oct 18, 2005 | 08:45 AM
  #173
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
hey ... sponsor me. haha i have a 05 g35 aps tt.. i need to save some money somewhere i just blew my motor.. building my internals now ...
but for real.. im probably ditching my unichip for this.
Old Oct 19, 2005 | 11:31 AM
  #174
BlackTuner's Avatar
BlackTuner
Brian
I will have basic base maps upon release.
stock car
Intake, Exhaust
Intake, Exhaust and Headers..
I will have many maps to choose from to keep you guys happy
Yes I can tune it.. Only if you let me pick up hot chicks in it..
Jermaine~
Old Oct 19, 2005 | 07:52 PM
  #175
Gman2004's Avatar
Gman2004
does anyone know what kind of boost controller they used on the MRC car in conjunction with the UTEC?
Old Oct 19, 2005 | 09:56 PM
  #176
theking's Avatar
theking
+1? Were you using the UTEC to actuate a boost solenoid or using a standalone controller?
Old Oct 20, 2005 | 04:35 AM
  #177
damen's Avatar
damen
Jermaine~
hey we can roll together, this is howard's homecoming this weekend. let me know if your trying to roll.
Old Oct 20, 2005 | 06:55 AM
  #178
Julian@RACEMRC's Avatar
Julian@RACEMRC
Hey all,
I have been folowing the UTEC threads with some interest,as you know. We have loaned Jermain one of our APS equiped TT cars for product development and testing. Jermain has been making some progress with our car and will be tuning either today or tommorow with the upgraded actuators and larger injectors. We are really excited about the UTEC comming to the 350Z market and are convinced it will be a whole new revolution in tuning VQ motors for years to come. The featuers the UTEC will have along with the free software updates and customer service will make the UTEC far more marketable than the Emanage IMO.some will dissagree with me on this,but only time will tell.Adam from Z1 and I both agree that over the EU the choice will be obviously clear cut.UTEC. We will be carrying UTEC's for the 350Z and will continue to work with Jermain on this project well into the future. We should have the car back later this week and be doing some 1/4 mile passes to prove that OUR cars are not DYNO QUEENS but are street,drift,and track proven. The 350Z community has come a long way in the past 2 years alone!!
Old Oct 20, 2005 | 07:26 AM
  #179
BlackTuner's Avatar
BlackTuner
Gman,
We are using our DTEC-BC.
It offers some cool features like:
RPM & Gear Based Boost Control
Closed Loop Boost Control
5 Boost Maps
45 PSI Map Sensor (also the same sensor used on the Z UTEC.)
Includes our Knock Lite
We can also add an additional solenoid to allow you to control the upper and lower port on a external waste-gate. This gives you the ability to apply and control the amount of positive pressure being applied to the top side of your waste-gate.Using manifold pressure to help seat your waste-gate, the advantage of this is that you can run very low waste-gate springs like (3-4 Psi.) so that you can launch on very low boost without blowing away the tires using the gear based boost control. Once you are in higher traction situations you can start ramping your boost to your higher boost targets.
Old Oct 20, 2005 | 07:31 AM
  #180
theking's Avatar
theking
That's what I thought! This is great! I've only heard good things about this controller.
Gman,
5 Boost Maps
