whats my next step ? with add ons
Old Aug 22, 2005 | 12:47 PM
raceredi's Avatar
raceredi
Default whats my next step ? with add ons
okay guys i would love to have a hardcore motor like everyone but where i live in maryland houses are not cheap so i have a limit to spending...okay so i have a greddy tt, fmic, unthox pulleys, pipes, cat back , greddy eo1, reflash, clutch, flywheel, nos intercooler sprayer with co2, limited slip....well i want more whp, but dont feel like building a block this yr, what can i do and in what order should i do it ..thanks
Old Aug 22, 2005 | 12:57 PM
Gman2004's Avatar
Gman2004
How much boost your running? If below 9psi, then boost it up to 9 and get it retuned.
Your next mod IMO should be the AAM or CJM Fuel return. It won't add more power, but it will give you more safety. If you build your motor you will need anyway.
Old Aug 22, 2005 | 01:37 PM
raceredi's Avatar
raceredi
i was also thinking of a fuel return too but not sure yet
Old Aug 22, 2005 | 02:49 PM
mojo powered's Avatar
mojo powered
I would say that it is a requirement and not an option with the greddy TT kit but that's just me.. not trying to open a whole new can of worms
I wouldn't even hesitate getting a return fuel system, then retune for 8-9psi.
Old Aug 22, 2005 | 02:53 PM
amolaver's Avatar
amolaver
want it to be faster? lose some weight (the car, not you ). CF hatch with lexan window is good for ~70 lbs or so i'm told.
ahm
Old Aug 22, 2005 | 03:00 PM
sentry65's Avatar
sentry65
the burninator
70?
no more like 35 lbs
besides, losing weight from the rear of this car is kinda counterproductive for handling
Old Aug 22, 2005 | 03:41 PM
amolaver's Avatar
amolaver
Originally Posted by sentry65
70?
no more like 35 lbs
huh - rickdogg (who has the hatch and lexan window) says 65lbs.
https://my350z.com/forum/showpost.ph...0&postcount=22
as far as the balance goes, i doubt it will have a major impact (especially if coupled with a lightweight battery). that weight is carried high, so losing some also drops the CoG, making everything else work better - tire load is more evenly balanced, less pitch and roll for the suspension to deal with, etc. i'm guessing its a still a net plus for all performance measurements - handling, accel, and braking. course, that's just a guess. maybe next year
ahm
Old Aug 22, 2005 | 05:15 PM
002-M-P's Avatar
002-M-P
With the turbo kit adding the weight it does to the front, then combining that with even lighter rear (if you already have spare and jack removed) probably will upset handling some. If you want to save weight I would say get a lightweight battery and possibly some seats.
As far as power is concerned I would say return fuel system, thats my next step in the process at least.
Old Aug 22, 2005 | 05:38 PM
Jaki's Avatar
Jaki
Another vote goes to the return fuel system. Get that and retune to the car and up the boost. Upping the boost does the same as adding a new performance mod... except in most case its a cheaper way to add more hp.
Old Aug 22, 2005 | 07:14 PM
sentry65's Avatar
sentry65
the burninator
suprised you don't already have a fuel return system
Old Aug 22, 2005 | 07:35 PM
taurran's Avatar
taurran
/agree on the fuel return.
Old Aug 22, 2005 | 08:06 PM
raceredi's Avatar
raceredi
well i guess its voted out to fuel return ......well the only reason i didnt get it was cuz it always seemed like alot of money for such a small boz of hoses , rails ect..but yea if that lets me up the boost then it sounds good to me
Old Aug 23, 2005 | 09:07 AM
002-M-P's Avatar
002-M-P
Yea, but you wouldn't realize what it takes to make those hoses. Once you learn all the processes that go into making the hoses you will see why they are so expensive. Then you have to pay for all the R&D that went into the making of the fuel system, esp. for the 350z.
Old Aug 23, 2005 | 01:29 PM
raceredi's Avatar
raceredi
thanks well this helps looks like now its just which fuel kit i need to get
Old Aug 23, 2005 | 01:32 PM
taurran's Avatar
taurran
I'd look into the CJM kit first.
35reilly
Sep 28, 2015 07:42 AM
samansharif
Sep 25, 2015 12:31 PM
