Anyone making over 600rwhp?
Old Aug 30, 2005 | 02:42 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by phunk
keep an eye out for issues with localized coolant temps... watch your coolant overflow and see if you can do 4-5 repeated runs thru 4-6 gear and see if it overflows out of the bottle. those are the conditions in which I was able to get the heat to really come on strong and cause localized boiling. i would be curious if running with open test pipes is enough heat evacuation to prevent this.
Hey Phunk, we tuned on a load based dyno and watch the overflow. Prior to running with open pipes, the coolant level would rise, but not overflow. The runs we made are roughly 8-10 seconds in 4th gear mostly. We never dide 5th gear because the dyno speed gets pretty scary...especially with a load based dyno. You could also feel the heat coming off the engine. When we removed the exhaust restriction, the coolant level never moved, and there was a notable decrease in engine bay temps.
I imagine your car would have been close to 600whp with the HKS F-Con, and an open exhaust.
The 550's are near the limit...thats for sure.
Old Aug 30, 2005 | 06:42 PM
phunk's Avatar
phunk
CJ Motorsports
sharif: just FYI i never did have coolant boiling on the dyno... i would get a little raise in the overflow, but nothing to write home about and it would eventually go back down. It wasnt until I started giving it hell in the higher gears on the street where I started to really get hit with the cooling trouble. I would be curious if the exhaust backpressure drop was enough to eliminate this issue.
Old Aug 30, 2005 | 09:05 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
it appears so...and i'm getting my custom 3" true dual very soon
Old Aug 30, 2005 | 09:09 PM
kzshin's Avatar
kzshin
yes, Espirit Japan, with RB26, 600hp. and it's a track car.
Old Aug 30, 2005 | 09:43 PM
mchapman's Avatar
mchapman
Is this a physical example of the difference between inertia and load based dynos.
Old Aug 30, 2005 | 10:01 PM
phunk's Avatar
phunk
CJ Motorsports
no. when tuning a car on the dyno i take several several minutes between passes as I make adjustments. When I was able to boil the coolant, it was when I did repeated runs in higher gears at loads that are much greater then a full sweep pass on any dyno.
Old Aug 31, 2005 | 06:24 AM
Sharif@Forged
Forged Performance
Thats correct. I was pointing out that we used a load based dyno, which will apply a realistic load on the engine, especially at higher RPM. The load based dynos, if anything, would increase coolant temps at higher RPM...all things being equal, when compared to a dyno jet.
Of course it's difficult to replicate drag, wind resistance, etc, but on the dyno, G_Man's coolant overflow bottle never budged with the zero back pressure exhaust setup. Hope that helps.
Old Aug 31, 2005 | 07:35 AM
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by Sharif@Forged
Hope that helps.
No... more innaccurate dyno chat doesnt help.
I am curious, if I had just removed all the exhaust backpressure in my car, if that would have stabilized the heat issues I was having. But since I doubt this car your showing us will ever go thru what I had to put my car thru to cause the problems... I will never know... I am changing too much this time around to isolate exactly what fixed it. I promise you that your dyno there was not creating anywhere near the load or the heat of what I was doing with my car to create the issues.
Run the car down some back to back 1/4 mile, repeatadly take it up to 170mph, do some burnouts and 360's in 100 degree weather..... Report back after the car does more than make a dyno graph without having cooling system issues... and let us know if the everything stayed cherry. thats all I am saying
Old Aug 31, 2005 | 07:43 AM
Sharif@Forged
Forged Performance
^^^Phunk^^^
My "chat" is not inaccurate. I was just pointing out that in my FOURTH gear runs, we are creating more load and heat than a dynojet inertia based dyno...that is an idisputable fact. A 1500lb drum (or whatever the exact weight is) spinning at 120mph is going to exert far less load on the motor than a load based dyno at the same speed.
My point is bring this up, was to let you know that we put more load on the motor than with a dynojet...thats all. I also acknowledge that your 5th and 6th freeway pulls put far more load on the motor than we did.
Old Aug 31, 2005 | 07:48 AM
phunk's Avatar
phunk
CJ Motorsports
have the dyno software convert to a rpm versus time graph and i will do the same, and then we can dispute this indisputable fact.
Old Aug 31, 2005 | 02:16 PM
uplz4588's Avatar
uplz4588
hahha charles u told me all these stories and theories months ago... they are finally comming out onto the boards, hopefully once shes all fixedup after winter ill FINALLY get a spin in that beast
sales@czp
Sep 23, 2019 03:30 PM
Tochigi_236
Sep 27, 2015 03:40 PM
