Club 600whp...Dress Code Stricly Enforced...anyone else wanna join?
Old Sep 12, 2005 | 06:12 AM
  #101
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
No, they both have the same stock clutch feeling, as long as you don't get the heavier pressure plate.
That is correct. If you chose the standard 1100kg pressure plate, they both will have a stock-like pedal feel.
Do you loose some drivability going from the ATS twin to the ATS triple?
I have driven the triple with standard pressure plate, and it felt nearly identical to the twin in terms of engagement and feel. According to Yasu from ATS, they claim that the ATS triple is actually easier to drive than the twin. But the heavier pressure plate does add 20% to the pedal pressure, and will make it harder to modulate.
Old Sep 18, 2005 | 05:22 PM
  #102
JisNis's Avatar
JisNis
Any plans to run the quarter mile?
Old Sep 18, 2005 | 08:58 PM
  #103
Sharif@Forged
Forged Performance
I actually went out this weekend, but a contantly slipping clutch preventing me from making and full force runs...its was pretty much a waste of time until I get the new triple disc ATS. Best time was 12.2@122 and I had to baby the clutch off the line...with a pathetic 2.0 60ft time.
Anything above 550whp should demand a triple disc carbon, or the twin disc with the heavier 1350kg pressure plate, IMHO. The triple carbon can hold 1200hp, and the twin with 1350kg pressure plate can hold 900hp. The twin with 1100kg pressure plate is only rated at 700hp. All of these quoted numbers are crank hp.
Old Sep 19, 2005 | 06:05 AM
  #104
t32gzz's Avatar
t32gzz
Sharif, did you warm up the clutch by slipping it before the runs? It will be interesting to see if the twin disc with the 1350 PP can hold over 600hp to the wheels.
Old Sep 19, 2005 | 06:29 AM
  #105
Sharif@Forged
Forged Performance
Abosolutely.....I performed a really thorough warmup prior to the runs. It felt good..very grabby and snachy as the discs warmed up. Bute after the launch, I think the clutch just gave up.
I think the 1350kg PP wil hold about 700whp-750whp...given the relative performance of the twin disc 1100kg PP.
Old Sep 19, 2005 | 02:10 PM
  #106
failsafe306's Avatar
failsafe306
I'm glad I upgraded to the triple then! Next year I'm going FCON and shooting for big numbers, after I upgrade axles.
Old Sep 19, 2005 | 03:30 PM
  #107
Sharif@Forged
Forged Performance
Yup..your clutch is on the way Chris....you will be well prepared.
Old Sep 20, 2005 | 06:55 PM
  #108
Carlitos's Avatar
Carlitos
Sharif, I have 585whp on my G with more than five 11sec 1/4 runs (11.3@124best) over 20 dyno runs with a ATS pressure plate,JWT disc, JUN fly/W and no problems so far. I think that you are hurting your clutch on the burnout box Then again, maybe mine is about to give up, who knows
Old Sep 20, 2005 | 08:07 PM
  #109
Sharif@Forged
Forged Performance
For the burnout....I rev it and pop the clutch. No slip, so I know its no damaging the clutch.
My clutch has just reached its limits...plain and simple.
When I take it out, I post pics of how it looks.
Old Oct 22, 2005 | 09:13 PM
  #110
JisNis's Avatar
JisNis
Any Updates?
Old Oct 23, 2005 | 06:26 AM
  #111
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Nah, Sharif has to do some other upgrades (triple-plate clutch just to name one). We've been extremely busy lately and most of the work that is done on his car since the 622 RWHP mark is testing new products.
Old Oct 24, 2005 | 06:55 AM
  #112
Sharif@Forged
Forged Performance
The triple disc ATS is in, and I finally fixed my rear main seal leak.
So my car is no longer a POS leaker. I have the 650cc injectors sittting on my desk....should be going in after SEMA, followed by a retune. I will be having a block machined with Darton sleeves, just as a backup. From all indications, anything above 600whp really demands sleeves....for longevity. I am sure plenty will run 600whp+ without sleeves, but I am seeing the first signs of headgasket failure/cylinder wall weakness at these power levels. Nothing major.....just seeing some interesting things here.
Old Oct 24, 2005 | 11:41 AM
  #113
t32gzz's Avatar
t32gzz
What interesting things are you seeing??? Inquiring minds want to know!
Old Oct 24, 2005 | 12:54 PM
  #114
G3po's Avatar
G3po
How's your twin clutch holding up. I have the same clutch being installed on a built APS TT G35.
Old Oct 24, 2005 | 05:09 PM
  #115
t32gzz's Avatar
t32gzz
My clutch is holding up just fine. I have the 1350kg pressure plate with the CCm coatings, and I think it helps a little.
Old Oct 24, 2005 | 05:30 PM
  #116
D350Z10's Avatar
D350Z10
Damn Carlitos you have a bad *** G!!!! Looks CrAZy HotT!!
Old Oct 24, 2005 | 05:48 PM
  #117
Sharif@Forged
Forged Performance
Just a little funky oily residue in the coolant overflow resevoir. No coolant consumption to speak of...maybe a tad.
Old Oct 24, 2005 | 05:49 PM
  #118
mchapman's Avatar
mchapman
EDITED, response above.
Old Oct 25, 2005 | 09:04 AM
  #119
G3po's Avatar
G3po
Great , same exact clutch config I have.
Old Oct 25, 2005 | 10:47 AM
  #120
barthelb's Avatar
barthelb
Master
This may throw a wrench in my engine build, have any more info/suggestions on this? Since i'm starting from the ground up basically i don't want to hose myself.
