is ball bearing worth it
Old Sep 13, 2005 | 04:30 PM
350zzzzzz's Avatar
350zzzzzz
Default is ball bearing worth it
hey every body i am in the market for some turbos and was wondering if ball bearing is worth it?
Old Sep 13, 2005 | 07:31 PM
g356gear's Avatar
g356gear
Yes...faster spool up...especially for larger turbos
Old Sep 13, 2005 | 07:36 PM
taurran's Avatar
taurran
+1
Old Sep 14, 2005 | 05:10 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
real ball bearing turbos are very much worth the money. Quicker spool up, means more useable power within your RPM range, which = a faster car.
I would highly recomend it.
Old Sep 14, 2005 | 08:09 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
what kind/size turbo are you looking at? What is the power goal and setup? Is this a customer turbo kit, or are you comparing some off the shelf kits.
Old Sep 14, 2005 | 09:39 PM
350zzzzzz's Avatar
350zzzzzz
no i was going to go with a greddy kit but now we are going to be making a custom kit probably using 2 garrett gt3582r's.after the motor is built im looking for around 800whp.
Old Sep 14, 2005 | 09:52 PM
ZON's Avatar
ZON
Sounds very inticing!! Who is "we"?
Old Sep 15, 2005 | 06:15 AM
Sharif@Forged
Forged Performance
Thats great. Without question, a dual BB setup like the Garrett GT series is a technologically superior product to a conventional Mits TD-05 turbocharger. But theory and pratical application can be very different. There are benefits to the water cooled BB setup, and I am not disputing those. Things like improved cooling, lubrication, and turbocharger longevity are all improved.
Oftentimes, "spool time" as people refer to it, is more a function of exhaust manifold design, exhaust system backpressure, and a proper boost controller...as boost controllers keep the wastegate closed as boost builds. I have driven the APS TT kits vs. the stock Greddy kit, and my seat of the pants impress is that spool up was comparable between the two.
It is far more important to properly match the turbocharger size and design, to your intended applications. But if given two perfectly match turbochargers, I would take the BB version easily. I just want people to know there are other factors involved in your decision.
Best of luck..let me know if I can help
Old Sep 15, 2005 | 09:24 AM
350zzzzzz's Avatar
350zzzzzz
hey thanks sharif like all ways you seem to impress me.hey i planning on going with either the emanage ultimate or the aem.but if i need any help from you i will pm you.thanks
and the we im talking about is the shop i work for its in my sig.
Old Sep 15, 2005 | 09:31 AM
JeffesonM's Avatar
JeffesonM
Have you considered the SFR twin turbo system? I believe the off-the-shelf setup comes with 60-1 hifi's but I think they can customize it to your needs.
Old Sep 15, 2005 | 09:35 AM
mojo powered's Avatar
mojo powered
I agree with Sharif .. (how can I not haha)
in a lot of cases, people go crazy about ball bearing and spend tons of extra money, which is well worth if you know what you're doing.
If you're already running a restrictive exhaust and a crappy manifold design, ball bearing is definitely not worth it.
Now, if you have the perfect straight through exhaust, an excellent manifold, a matched turbocharger size to your displacement etc then you will see huge benefits by changing nothing but internals of the turbo to real ball bearing. Better spool up, better midrange AND better top end.
But as I said, in a lot of cases, there are other areas that are just as important if not more that you can improve for possibly cheaper and easier before considering ball bearing. The same exact turbo could cost you nearly twice as much in ball bearing form and should not be up on your priority list unless you have the other components I mentioned adequate for the performance levels you're looking for.
Old Sep 18, 2005 | 07:27 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
As far as I know, the AEM Engine Management System is still in R&D for the 350Z. If you do use the Universal application EMS, you will most likely (I believe it is 100%) have to switch to throttle-by-cable.
Obadabot
Jun 18, 2023 11:31 PM
ablaine
Nov 29, 2016 10:13 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
samansharif
Sep 25, 2015 12:31 PM
