SES P0300 code
Old Oct 3, 2005 | 02:20 PM
  #41
booger's Avatar
booger
How low are you running the static preasure now ? I had my preasure set at 52psi with the vacuum line hooked up , but have gone back and reset to 52psi with the vac hose unhooked . Ive yet to clear the code since and dont know if its doing it any less
Old Oct 3, 2005 | 02:31 PM
  #42
theking's Avatar
theking
With the staic pressure(vac unhooked) set at 48psi i rarely get the code because I have it scaling the injectors less. As I turn up the static pressure to 52psi, I turn up the maf scaling and it happens much more. I am soon going to the UTEC and a FJO low impedance injector drivers with big 72lb injectors so that I can run a normal static pressure such as 42psi and have a nice respectable part throttle and idle.
Old Oct 3, 2005 | 02:41 PM
  #43
booger's Avatar
booger
I have TS flash for my 550 injectors . Do you think lowering the static preasure will help get the code less often ?
Old Oct 3, 2005 | 02:43 PM
  #44
nitrous350's Avatar
nitrous350
I have Same problem
APS TT Kit , Fuel return system , test pipe , cat back .....
But only at idle Only
Old Oct 3, 2005 | 03:00 PM
  #45
theking's Avatar
theking
That is my humble opinion.
Old Oct 11, 2005 | 02:09 PM
  #46
booger's Avatar
booger
I think most of the F/I are getting it . It has to be one of the three things I changed all at once when we did the rebuild . CAS wire , bigger RC injectors , and the return fuel system with in tank pump upgrade
I forgot to add the cams in this...so its four things I changed when the motor was rebuilt
Old Oct 11, 2005 | 02:14 PM
  #47
Chebosto's Avatar
Chebosto
?? i've never had this issue with my PE TT 10k+ miles so far.. ... Gringott? maybe he can chime in if he's gotten it on his car..
Old Sep 2, 2006 | 04:32 PM
  #48
Mr_pharmD's Avatar
Mr_pharmD
any updates on the p0300 code??? I have a little misfiring at idle and cant figure out why. This is on a vortech sc no upgraded return fuel line.
Old Sep 2, 2006 | 04:50 PM
  #49
booger's Avatar
booger
Cams ? If not i would check for a vacuum leak
Old Sep 2, 2006 | 06:40 PM
  #50
Z PHAT Z's Avatar
Z PHAT Z
I haven't had that p0300 code for a long time now
Old Sep 2, 2006 | 08:36 PM
  #51
Mr_pharmD's Avatar
Mr_pharmD
stock cams and from the boost gauge its around 20 in vaccum.. It hasnt come back after the reset but when I start her up it seems to idle wierd for a few sec (shake, put) and go to normal bounching from a/f ratio of 14-17
Old Oct 28, 2009 | 06:08 AM
  #52
damen's Avatar
damen
same here, i issue is at idle and i have a single turbo set up. i've had it on the car for over 4yrs and now it wants to show up as i'm ready to sell the car.
Old Oct 28, 2009 | 08:18 AM
  #53
mw9's Avatar
mw9
https://my350z.com/forum/maintenance...o300-code.html
Old Oct 31, 2009 | 07:32 PM
  #54
fklentz's Avatar
fklentz
Right after I had my install I would get this everytime I refueled. Now I rarely get it, so few I can't remember when the last one occured. I'm thinking it's related to fuel pressure, it would show up about 10 seconds after starting the engine after filling up the tank. What I started doing was turning the ignition on but not starting until fuel pressure was up and stabilized, maybe 4 or 5 seconds. The problem with clearing a CEL prior to emissions testing is there is test data held in the ECU that must be there to pass and it takes a while for the complete test sequence to occur to validate emission performance.
Old Nov 2, 2009 | 08:28 AM
  #55
Z PHAT Z's Avatar
Z PHAT Z
Tried that many times and the same happpened. It can be many things to it.
Old Nov 2, 2009 | 06:18 PM
  #56
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Z PHAT Z, it's been a while! Do you still have your Z?
Old Nov 2, 2009 | 06:45 PM
  #57
Z PHAT Z's Avatar
Z PHAT Z
Yes I do! Fully built long block with head works and cams. Equipped with Greddy TT kit and Water/Methane kit. I still got that code and can't seem to fixed it so I sent in my ecu to disable the code.
Old Nov 2, 2009 | 07:17 PM
  #58
Chris@FsP's Avatar
Chris@FsP
That's great man! Good to see you stuck with it, I know you had some difficulties getting it all together.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
