Who says Vortech can't make big power - Part 2
Originally Posted by mcduck
I agree with LouZer here...
475rwhp with a Vortech is impressive. I can the mods in his sig. I have a pretty good idea how they got it there and with his set up and more tuning time it sounds like they can dial in some more power. Good Work!
BTW did you ever get that CAI worked out for the Vortech? I was going to fabricate one in the near future.
John is making 435rwhp w/ the 2.87 pulley. He reached 505rwhp when using the intercooler chiller. Our setups are similar. He has the JWT cams, test pipes, etc. The biggest difference is the fuel system. I have larger injectors, fuel pump and a new fuel delivery system. He is still running the Vortech aux fuel pump with stock injectors. I don't know how much psi he is getting.
Originally Posted by LouZer
Wow, a Vortech makes 475 to the wheels and all you can see is the A/F on the graph.
If the car is a little running rich right now, I wouldn't worry too much about longevity, but thanks for your concern. booger asked about the timing as well so I will find out.
and don't get so defensive with the criticism here...
i have great assurance that when i ask a question or post a result on this forum that i will get lots of feedback...teaching me more about what other people are doing and what the "norm" is...this isn't an attack, some may come across that way, but you should welcome the critisism of others who have more experience
that's great that you are making 475 with a supercharger... hopefully the tune will be dialed in a bit better, you'll probably make more power and have a cleaner/steadier feel to the pull of the car
Great numbers....got 374 with stock pulley...going with the smaller one and new plenum to see what I get. Just want to be over 4 with the Vortech and I'll be happy. Nice to meet you on Sat Andy (McDuck).
374 is pretty good with the stock pulley. I only made like 360 out of the box. You can definitely hit 400+ with the 2.87 pulley and possibly with the 3.12 as well.
Thank you!
Nope. John has stock internals. Lucky guy I guess. I bent 5 rods.
Yeah, the chiller is great. It cools the intake temps considerably which leads to better combustion and more horsepower. It is probably safer than other options to push the horsepower limit because you will only increase horsepower after you spray the intercooler.
John has a really nice setup with an automatic bottle opener, purge system, etc. I definitely plan on installing one in the not so near future.
just remember with the n-ter-cooler you are lowering the charge temps, effectively leaning out the a/f curve. make sure you fatten the fuel curve a little to compensate for when you spray the cold stuff on the intercooler.
Just wondering, since you cannot adjust the SS box on the fly, how he set his timing and a/f ratios to take the best advantage of the intercooler sprayer yet not sacrifice his non-spray power much.
I can't say for sure, but I believe his A/F is somewhat rich. Somewhere in between 10-11. So there is no worries. As far as the timing goes. I don't think it is any different than if he didn't have the chiller. I will try to find out for you Andy.
If he gets extra boost from the chiller , its possible to have both tunes on the same map . As the boost curve would be in a different area of the map . Dont know ????
