Tuning gurus (Split Second / R4software)...
Old Oct 19, 2005 | 02:49 PM
prescience's Avatar
prescience
I'm learning loads of stuff here about the car and Vortech
So a conclusion is that there is probably no optimal tune but there are any number of optimum tunes at a particular RPM as a function of a/f and timing.
There are a lot of ways to 'skin a tuning cat' then - a British expression.
Any other important factors (apart from minimising detonation whilst optimising power) that tuners consider when doing the a/f and timing optimisation?
Old Oct 19, 2005 | 05:20 PM
booger's Avatar
booger
Originally Posted by Sharif@Forged
Yes I would...but a slightly different slope. Timiing should follow the trq curve. I have noticed that the SC's tend to produce flatter trq curves towards redline, so I wouldnt advanced as quickly as I would with a TT setup and a rapidly dropping trq curve. But there still needs to be some advance towards redline, for the engine to operate correctly.
Would you do the same thing on a stock block ?
Old Oct 20, 2005 | 05:04 AM
prescience's Avatar
prescience
BUMP - Good question?
When TT is on full boost, I would think trq curve declines vs rpm beyond peak trq like a NA trq curve (shapewise, I mean)? So maybe the same timing logic applies? SHARIF?
Old Oct 20, 2005 | 08:26 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Yes, what I wouldnt use as much advance across the board.
For instance, on a stock high compression motor, you might start at 10 degrees advance, and work your way up to 20 degrees. On a built low compression motor, you migh start at 15 degrees total advance and end at 25. These are just numbers, as it depends on boost, AF, octane, CR, etc....but just to give you a general idea of my logic.
Old Oct 20, 2005 | 10:01 PM
krazE's Avatar
krazE
how is the stock vortech map in terms of reliability?
Old Oct 21, 2005 | 06:44 AM
Sharif@Forged
Forged Performance
Safe, rich, and convervative...but underpowered.
Old Oct 21, 2005 | 07:33 AM
jpc350z's Avatar
jpc350z
Are you referring to both maps? A/B?
2ndchanceZ
Oct 26, 2015 08:03 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
