what are your thoughts on DTA standalone
Old Oct 18, 2005 | 10:40 PM
Gman2004's Avatar
Gman2004
Default what are your thoughts on DTA standalone
A shop in my area is a doing a full build (greddy tt, rods, pistons, sleeves, port polish, etc.) on a 350z and they are putting in a DTA standalone. The tuner says he can get the DBW to work with this unit. Anyone heard of it? What are you thoughts? Here is some info on it and the website. The model is the P8PRO. www.dtafast.co.uk
P8PRO Features
Without doubt the worlds most user friendly mapping software - FREE!
Eight individually controllable coil drivers for unequal firing or different cylinder advance.
Eight injector drivers, with individual adjustments, for sequential injection up to eight cylinders or control of up to 16 staged twin injectors.
Amplified Coils Support NEW
Full 3 or 4 wheel traction control with switchable, on dash, on/off and wet/dry settings.
Launch control with numerous options.
Turn off closed loop above TPS & RPM NEW
Full turbo anti lag facilities, switchable on dash.
Logging switch able on dash NEW
Voltage in warning limits during Mapping NEW
Manifold Pressure as main load NEW
Improved idle speed control NEW
Nine auxiliary outputs for various functions.
Improved, more flexible data logging capabilities NEW
Compensation for air temp / water temp / MAP or barometric pressure on fuel and ignition.
Closed loop Lambda control.
Full turbo pressure control variable by RPM with overboost protection.
Steering wheel button controlled start line RPM limit.
Full power shift cut.
Temperature dependant idle speed control via PWM valve.
Dedicated shift light output.
Serial output of data for dashboard NEW
Dedicated Tacho output.
Two stage main RPM limiter.
Dedicated fuel pump control.
Full start-up fuelling map.
Throttle transient enrichment map.
Self test facilities for ignition and injection.
Diagnostics and peak recording.
Real time mapping, no EPROM's required.
Selectable 20 X 14 lambda target map
In-vehicle fuel map building
Can use 5 volt linear lambda sensor with external electronics
Software programmable for most crank wheels, (Honda Blackbird, Rover, 36 - 1, 60-2 etc).
All main 3D maps (20 x 14) have user programmable break points.
Max. RPM 16,000.
Flexible PWM outputs linked to any input useable for any of the following;
Water injection (multistage)
Speed related power reduction (Drag bikes)
NOS control with fuel enrichment and ignition retard (multistage)
Fuel Mixture control for endurance racing
Twin Fuel pump control
Anything else requiring mixture and ignition control
linked to an input and an output.
Old Oct 19, 2005 | 08:08 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
If you are going to go with a racing standalone engine management system, I would go with Magneti Marrelli. Some F1 cars use this.
A member on the board has made a harness for our car with this. I think there are two or three options, if you want to know more information about these units, i'll find the old PM and post it up. BTW, Injected Performance is using one of the two (or three) units available. ( https://my350z.com/forum/forced-induction/124849-injected-performance-350z-4-3l-spy-photos.html )
Old Oct 19, 2005 | 08:27 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Whats the MSRP on this? Looks very similar in function to the Motec M800.
Old Oct 19, 2005 | 08:29 AM
Gman2004's Avatar
Gman2004
I don't have that info, but he quoted me $3,200 installed and tuned.
Old Oct 19, 2005 | 09:29 AM
G352NV's Avatar
G352NV
Holt ****! I thought I was crazy!
Old Oct 19, 2005 | 09:37 AM
dynamic6er's Avatar
dynamic6er
This really depends on the level of factory functionality that you wish to keep. I get the impression your installer does not really understand the full scope of the factory ECM and its complete integration to the rest of the factory systems. I can almost garentee that this system will knock a fair amount of your factory components out of commission. To include your dash and other parts.
The DTA systems are nice. We've tuned a few here but on straight SCCA race cars. They work well in that regard. I believe they are based on the GEMS board and software (the same company that makes AEM's EMS) although the screen shoots look much cleaner from an interface perspective.
I promise you that this is a very large job and $3200 seems quite low, but I'm not familiar with your installer. This type of system is going to come down to the installer. Honestly the risk is not worth it. There are two garenteed choices the Motec (if you wish to self tune the system) or the HKS F-Con PRO. Obviously I'm biased becasue we are an HKS F-CON PRO dealer but these are the pros. First is 100% proven. We've installed and tuned it on 12 cars. It functions and operates flawlessly. Start-up is so factory-like, you would never know its heavily modded. Cruise and idle are perfect. WOT is an thrill. Also its reasonably priced when compared to the Motec (over $6000 just for parts). The HKS F-CON is ~$4500 including ECU, Harness, WBo2, Sensors, Install, and Tuning. I cannot stress enough how hard installing a standalone system is in this car. Please call me and I will be more then happy to explain. Its much to much to transmit through writing.
Old Oct 19, 2005 | 09:48 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
same as any other standlone honestly...the trick to standalones is NOT the one you pick, but rather the person who tunes it.
Old Oct 19, 2005 | 09:52 AM
Gman2004's Avatar
Gman2004
He told me I would not lose any OEM functions, because the factory ECU will still control them inlcuding the DBW. I will definately wait to see this on the 350z project they have before I opt to take this route.
I was going to get the HKS, but decided against it for two reseans. 1. Limited tuners. 2. If I am paying $4,500 for it, I would expect not to lose any functions like VDC and cruise control. For that price they better get it right.
Brandon@Forged
The MoTeC M600 is actually only around $4500 USD, including harness and etc.
I was under the impression that no HKS Pro-Dealers had fixed the cruise control, TCS/VDC, etc. feature problems that most lost (whether completely or not) when using the V-Pro.
Old Oct 19, 2005 | 09:53 AM
Nano's Avatar
Nano
A member on the board has made a harness for our car with this. I think there are two or three options, if you want to know more information about these units, i'll find the old PM and post it up. BTW, Injected Performance is using one of the two (or three) units available. ( https://my350z.com/forum/showthread.php?t=124849 )
both the megane trophy renaults
and the formula renault cars
use magneti marelli marvel 6r as engine management
the magane racecars uses a 330hp almost stock VQ35DE
the formula racecars use a 420hp heavily tweaked VQ35DE
Old Oct 19, 2005 | 09:57 AM
Gman2004's Avatar
Gman2004
If you get the Motec and all harnesses will it be plug and play like the UTEC?
Old Oct 19, 2005 | 10:00 AM
Brandon@Forged
Originally Posted by Gman2004
If you get the Motec and all harnesses will it be plug and play like the UTEC.
I would have to check with Simon@Nizpro or Richie (300+RWHP N/A 350Z using the M600) to find out.
To give a guess, I don't imagine so.
Old Oct 19, 2005 | 10:11 AM
dynamic6er's Avatar
dynamic6er
Haha my fault. I read this thread
https://my350z.com/forum/showthread....ighlight=motec
but forgot it was in AUD not USD. Well I guess I can always tell Peter our currency is better engineered then his.
I have not kept up with the thread. Does the Motec retain all those functions (VDC/Cruise)?
Old Oct 19, 2005 | 10:18 AM
Brandon@Forged
No problem.
Yes, they had some problems with the DBW initially, but from what Richie has posted, all has been worked out.
His car is a daily driver, BTW. He is a real estate agent, so promptness is important (and i'm sure he has no problem with that kind of power).
Old Oct 19, 2005 | 10:39 AM
UnderPressure's Avatar
UnderPressure
Support use to be, what's the kind word, lacking, w/ DTA. Frank the US distrubtor, really didn't use to know his head from a hole in the ground. He use to be the only outlet for DTA here stateside. Things might have changed in the past few years but DTA USA use to be a part time 1 man operation.
As for pricing. The 3,500 quote is way too low. There is no way a competent shop is going to install a standalone w/ DBW and tune it for that price. If they believe they can do a quality job for the little money and retain all the standard features, it just goes to show how poor a grasp of the situation they have. To give you an example. There is no, I repeat no, standalone out one the market today that retains all of the OEM features. The gauge cluster must be run by the stock ecu, VDC in the the form Nissan designed is disabled, CC is gone.
Here is a bit of info on the Magnetti Marelli system. An SRA w/ wiring harness is going to be ~$5-6.5k. This will include DBW, CVCC, Traction contol, 8mb Data logging and a wiring harness built to IRL specs. You can choose to run the stock ecu as well to control the rest of the vehicles functions. The only features you will loose @ this point are VDC, & CC. The MM traction control system is pretty damn good so the vehicle will still be able to obtain straightline traction but loose the intigrated braking functions of VDC. MM will only allow this ecu to be sold and installed thru their authorized distributors. In otherwords, unless MM has confidence in you as an installer and tuner you can't even order the ECU. They care to protect their name and image as the best in the world that much.
If someone is interested in obtaining a MM ecu. Contact me. I have been working w/ MM since 2004 on the ecu specifically for the 350z's.
Justin100
Nov 25, 2021 06:26 AM
apex locator
Jul 23, 2021 02:27 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
