Motor is officially BLOWN! Yes it was Forged
Old Nov 9, 2005 | 01:23 PM
  #81
neffster's Avatar
neffster
Originally Posted by 1G'
Hope your having a change of hart now!?!
your not one to give up, i can tell.
Are you talking about the car or the marriage?
Old Nov 9, 2005 | 02:52 PM
  #82
theking's Avatar
theking
Nice Todd!
Old Nov 10, 2005 | 01:45 AM
  #83
MySunset350Z's Avatar
MySunset350Z
not sure if this was already mentioned.
a compression test was done prior to the leak down and the numbers where between 110 to 125psi with the lower compression setup. shouldnt there be a larger pressure difference with a blown motor? 15psi doesnt seem like much.
Old Nov 10, 2005 | 12:29 PM
  #84
350zDCalb's Avatar
350zDCalb
builtZmotors
u guys are all using the term "blown motor" as if a rod broke through the side of the block...
this term is usually used when the failure is catastrophic, or at least something breaks!!!...the exact cause of the smoking will be made apparent (hopefully) when the motor is dissassembled...if the piston ringland broke, or a ring is toast...then no, the compression numbers do not have to differ more than 15psi...if a piston was shattered , then yes, the numbers would differ much more
good luck jorge!
Old Nov 10, 2005 | 06:53 PM
  #85
crmd37's Avatar
crmd37
hey i'm getting the SGP motor build also with ;
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
*Darton MID Sleeves (upgrades to a 3.8L)
New Main and Rod bearings w/ceramic coating
Pauter Rods
ARP Rod Bolts
CP Pistons/Arias Ultimate..your choice(8.5:1 or 11.5:1)
Ceramic coating on Piston skirts and tops
ARP Main Studs
ARP Head Studs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
*Tomei Upgraded Cams
*Ferrera 1mm Over Valve Train
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New Nissan Head gaskets
New Nissan Oil Pump
New Nissan Cam seals
Also getting the Walbro fuel pump, AAM Fuel System, 740cc injectors, Quaife LSD, Oil cooler, new radiator, New Clutch and the GReddy TT with 20G upgraded turbos...can you guys tell me anything to watch for or anything else I should need? I'm going for close to 700rwhp also, might get a forged crank and new axles as well! This will be my daily driver also. Anyways, let me know what you guys think I should do.
Old Nov 11, 2005 | 02:39 AM
  #86
neffster's Avatar
neffster
Originally Posted by crmd37
... Anyways, let me know what you guys think I should do.
Maybe start your own new thread.
Old Nov 11, 2005 | 04:23 AM
  #87
Gman2004's Avatar
Gman2004
Block redecked
Crank balanced
Pauter Rods
ARP Rod Bolts
ARP Main Studs
ARP Head Studs
Heads redecked
5 angle valve job
Cold Clearance set
New Nissan Oil Pump
Since you are going all the way you might as well get a full stand alone EMS. It looks like you have a pretty big budget, so I would go with the Motec. It will cost you around $5000.
Old Nov 11, 2005 | 06:18 AM
  #88
roncfpz's Avatar
roncfpz
You should watch out for other cars and you'll need a radar detector!
Wow, that's an impressive list.
Good luck!
Ron
Old Nov 11, 2005 | 06:44 AM
  #89
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The crank is already forged chromoly steel, and has been tested to 1000-1300whp so I dont think he need a new one.
You are going to need more fuel pump capacity to reach that power. The Walbro starts fading at about 575whp...you can tune around it to some extent, but once the pressure starts dropping, its time for an additional higher capacity pump, twin walbro..or some other solution. A signle Walbro 255 will not get you to 700whp safely.
Old Nov 11, 2005 | 07:34 AM
  #90
Gman2004's Avatar
Gman2004
Default Car is shipping today
Hey all,
The trucking company will pick up the car this evening. Right now I have a detailer giving her a good wash and a Zaino application before she leaves for TX.
Old Nov 11, 2005 | 07:49 AM
  #91
t32gzz's Avatar
t32gzz
Good luck Jorge.
Old Nov 11, 2005 | 10:33 AM
  #92
G352NV's Avatar
G352NV
Originally Posted by Gman2004
Hey all,
Its about time that thing gets cleaned! Tell them to do the wheels also!!hahahaha
Old Nov 11, 2005 | 10:35 AM
  #93
Gman2004's Avatar
Gman2004
hahaha....I already told him to get the wheels.
