Here we go... FI and first SES light. Comments please.
Old Nov 2, 2005 | 03:37 PM
neffster's Avatar
neffster
It's about 0.3-0.5 higher than normal worst case. Normally, if I'm under boost around 3500-5000 rpms it's low/mid 11's and above 5000 it begins dropping to 11.2 then finally 10.8 near redline. When it was 50 degrees the last few mornings I'd see 11.0 at WOT/redline and 11.4/11.6 in the 3500-5000rpm range. Also, I'm told I'm pulling 6 degrees of timing, but I'm not sure if this is gradual, or if it varies at different rpms. Maybe someone from CP Racing could chime in...
This morning the temp. was ~65 degrees Farenheit (no where near as cold as it has been lately) and I was just cruising along in 5th gear at ~50mph when the light came on.
Old Nov 2, 2005 | 10:11 PM
theking's Avatar
theking
Then you code is a random/strange occurrence and nothing to worry about. But knowing you Todd, you still will, lol. Your AF's sound good and the typical good work Sharif and CPRace normally produce. Talk to you soon(Friday, at the track).
Old Nov 3, 2005 | 03:52 AM
neffster's Avatar
neffster
Yeah, I was really worrying this morning as I was practicing my launch, 2nd, 3rd and 4th gear shifting techniques for the track on Friday. Darn, that launch is tough now but when you hit it right... yeah baby!
Old Nov 3, 2005 | 06:40 AM
CpraceZ's Avatar
CpraceZ
As I have said before your car is safe, the A/Fs are safe that you say you are seeing. 11.2 A/Fs which is the highest you say you are seeing is far from dangerous
Old Nov 3, 2005 | 12:02 PM
psychoticminds1's Avatar
psychoticminds1
All cars will do the flashing ses light thing it means "danger to catalyst" and normally throws when an ignition coil blows becasue then the car is dumping gas into the cat and destroying it. But yea flashing ses is a definat sign to pull over i mean it wont kill the car the worst thing that will happen is you will light the cats off. Althoguh its kinda cool to see a red glow coming out from under the car at night lol j/k
Its probably the flywheel doing it and throwing a p0300 code (Random missfire) becasue the crank angle sensor is used to detect missfires by the speed at which the crank rotates becasue remember for one full revolution of the crank it accelerates and decelerates 6 times each one accel each cylinderfiring now the com knows the timing on this and with a light flywheel this all happens faster making the computer have a F*cking heart attack lol
Old Nov 3, 2005 | 12:56 PM
neffster's Avatar
neffster
I know, I know. I guess sarcasm is tough to detect over the internet, even with smileys like this one.
BTW, I wouldn't flog on my car if I even had a hint that something was wrong. See you guys at the first part of next year for some more goodies.
Old Nov 4, 2005 | 10:50 AM
CpraceZ's Avatar
CpraceZ
sounds good buddy if you ever have any questions feel free to call
Old Nov 4, 2005 | 12:29 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
All good. Unfortunately, with FI, its not uncommon to see check engine lights. Random cylinder misfire is pretty common, and nothing to worry about in most cases..assuming the car is properly tuned. Best of luck!
Oh, and if you check the boards, lightened flywheels are known triggers of the random cylinder misfire. The random misfire code is trigger by the crank angle sensor....FYI.
Old Nov 5, 2005 | 03:37 AM
neffster's Avatar
neffster
Thanks, I'm learning more and more every day.
Old Nov 5, 2005 | 06:17 AM
Sharif@Forged
Forged Performance
Glad to help!
May 30, 2017 03:28 PM
350Z Project X
Oct 17, 2015 05:16 PM
bneumann
Oct 7, 2015 12:16 PM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
