good news!
Old Nov 7, 2005 | 12:08 PM
tig488's Avatar
tig488
Default good news!
i wired my WG shut, and the car holds 10psi till redline, time to order a heavier actuator from Forge.
Old Nov 7, 2005 | 12:17 PM
phunk's Avatar
phunk
CJ Motorsports
10psi to redline is cool, but it only makes 10psi with the wastegate 100% shut?
Old Nov 7, 2005 | 12:19 PM
tig488's Avatar
tig488
it probably about 97% shut, i cant pull the wire tight enough to make it seal 100%. why what are you thinking?
phunk...youre killing my buzz.
Old Nov 7, 2005 | 12:29 PM
phunk's Avatar
phunk
CJ Motorsports
i was just thinking of how much power is the kit good for if on a built engine if it cant come up with more than 10psi.
Old Nov 7, 2005 | 12:32 PM
Git-R-Done's Avatar
Git-R-Done
Another fine example of the bullshat that APS spews forth in their false claims and outright lies.
Old Nov 7, 2005 | 12:34 PM
phunk's Avatar
phunk
CJ Motorsports
well lets not crucify them just yet. This is only one case... perhaps he has a charge leak somewhere or something.
xxlbeerZ's Avatar
xxlbeerZ
Uhhh.. someone already ran 12psi, tig has leaks.
Old Nov 7, 2005 | 12:36 PM
Bullitproof's Avatar
Bullitproof
i'm not familiar with tig's situation, but maybe not all aps kits are created equal. my kit is using a turboxs manual boost controller and holds .6-.7 bar to redline consistenly.
Old Nov 7, 2005 | 03:27 PM
tig488's Avatar
tig488
actually the max im hitting is 13.2 pounds right now, but my ***** arent big enough to get much more than that. ive been hitting 12 pounds consistently with my manual BC but it would never hold it until now.
i did have a charge leak abd thought i fixed it. maybe i didnt and the wired WG is just compensating for the leak.
Old Nov 7, 2005 | 03:42 PM
dirtroad's Avatar
dirtroad
are you going to be running 91 or 93 or 100 octane? my tuner told me that I'd need to run higher octane if i messed with the actuator springs.
Old Nov 7, 2005 | 03:45 PM
tig488's Avatar
tig488
im using 93 with a 93 tune.
Jambo016
Sep 16, 2016 01:08 PM
