RPM signal with Zeitronix
Old Nov 10, 2005 | 02:58 AM
prescience's Avatar
prescience
Default RPM signal with Zeitronix
Have ZT-2 running with AFR, EGT, Boost and lambda where do i splice from to get the RPM signal (for connecting to Zt-2 green wire, pin #3).
I've seen a thread on this recently but can't find it now
Post any wiring diagrams you think might help
Old Nov 10, 2005 | 04:52 AM
SungNamZ's Avatar
SungNamZ
Check out this thread: http://g35driver.com/forums/showthread.php/t=40388 It has been a long time, but you might also go back and check some of my previous threads/post on Zeitronix. Looking through some notes I think it is terminal #62 Yellow/red wire on the ECU harness connector. That's assuming Nissan hasn't changed things.
Old Nov 10, 2005 | 05:26 AM
booger's Avatar
booger
I think it was pin # 62 , but dont trust the wire color . Make sure on the pin #. If you have a service manual , you can look it up in there
Old Nov 10, 2005 | 06:52 AM
tig488's Avatar
tig488
yep just did it a few months ago.
Old Nov 10, 2005 | 07:29 AM
prescience's Avatar
prescience
Thnx guys. Any issues splicing off that wire and thus changing the impedance of the circuit i.e. knock-on effects elsewhere.
Does the wire (on pin #62) have a particular name
Old Nov 10, 2005 | 12:08 PM
prescience's Avatar
prescience
The service manual I have says
Pin#62 Yellow/Red is Ignition Signal No 1
Pin#50 Green TPS No 1
Views?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
etkms
Jun 19, 2022 06:30 PM
Justin100
Nov 29, 2015 03:58 PM
hardwood66
Sep 8, 2015 04:31 AM
Daniel_dh
Sep 7, 2015 12:56 PM
